Intake runner length....technical question
Old Mar 18, 2010 | 11:05 AM
06isDriver's Avatar
06isDriver
I too thought that would be a potential issue but I havent actually witnessed it happening. I used one of those snake cams to view the interior of the pipe while the test system was running and not once did condensation form.
Trust me....I have my eye on it. I've considered programming the controller to account for humidity and temp differences in real time to reduce the chance of condensation buildup but for now its non issue and would add complexity that doesnt seem necessary.
Plus...to tell you the truth, I dont know if it would actually cause any real problems having it injest a drop of water or two every now and then. People have used a water injection system for decades. I think it first started with the army supplied jeeps back in the 50's and 60's? I'm not too sure on that.
Old Mar 23, 2010 | 10:55 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Water injection dates to Harry Ricardo's work in the 1940's on aircraft engines. Condensation isn't really a problem unless the water goes solid and forms ice. Ice tends to make throttle butterflies stick which is why you have coolant running through the throttlebody - there's a huge temperature drop inside the throttlebody at part throttle because the pressure differential is so great. The OEMs all worry about this causing icing, so they run hot coolant to ensure no ice forms.
LB Lex
GS - 1st Gen (1993-1997)
43
Mar 25, 2009 02:18 PM
MattIS
Performance
Jul 23, 2007 01:38 PM
Drexenol
Performance
Apr 10, 2004 02:23 AM
