Unorthodox cam gear???????
Old May 6, 2002 | 02:02 PM
LexusL's Avatar
LexusL
Question Unorthodox cam gear???????
Has anyone have Unorthodox cam gears installed in their GS, and if so did it made any noticable differences in power?
Old May 7, 2002 | 09:39 AM
v300's Avatar
v300
LexusLORD,
On a GS300 it provides an additional 7hp to the wheel pickup on the dyno. However, if you want to get into advance power/torque (forced induction) you're going to have to switch back to the factory pulley.
Let me know if you're interested.
Old May 7, 2002 | 01:01 PM
LexusRules's Avatar
LexusRules
Originally posted by v300
LexusLORD,
why is that? how does it change teh cars sound?
Old May 7, 2002 | 05:12 PM
LEXter's Avatar
LEXter
Default pully
read somewhere that these pully screw up your engine....and especially when there is a mega audio system in the car...u should not even consider installing the pully.....coz it reduces the eletrical power into the car............
just for ur knowledge.....
Old May 7, 2002 | 06:48 PM
JYOO
Guest
Posts: n/a
Pulleys DO NOT ruin your engine. I had a set of underdrive pulleys on 2 of my previous cars. They dont give u power u can really feel but if u pay close attention, there is a power gain. But if u have a big system...not recomended.
Old May 7, 2002 | 10:23 PM
zenki300's Avatar
zenki300
Oh boy. I hope you're not listening to them... talk about misinformation. You're better off asking this question at a Supra forum. All I can tell you is that pulleys (which everybody here assumed you were talking about) and cam gears are not the same, and I'm sure you knew that already. Stay away from the pulleys (fyi they don't come with dampers that are needed to absorb the shock), but the cam gears should be a safe investment. Just do a little more research.
That is all.
Old May 9, 2002 | 07:53 PM
v300's Avatar
v300
Originally posted by zenki300
Oh boy. I hope you're not listening to them... talk about misinformation. You're better off asking this question at a Supra forum. All I can tell you is that pulleys (which everybody here assumed you were talking about) and cam gears are not the same, and I'm sure you knew that already. Stay away from the pulleys (fyi they don't come with dampers that are needed to absorb the shock), but the cam gears should be a safe investment. Just do a little more research. That is all.
I go on Supraforums too. I believe there is also a distinction between stock, BPU and APU. I agree that the harmonic balancer is necessary under high boost condition where the engine RPM will run more rapantly. But under sub low-reving 6000RPM engine speed the Unothordox pulleys does not stress the crank as much as you think. We are talking about a VVT-i based engine where the ECM SELECTS the ideal intake and exhaust valve overlap under ALL engine operating conditions. Regardless, I ran the pulley (same diameter as factory) on my stock engine for almost a year and it was fine. I also dynoed the car at UPRD's old location in Huntington Beach.
Old May 10, 2002 | 05:07 PM
BadBtsz4u's Avatar
BadBtsz4u
What does apu and bpu stand for in reference to Supras?
Old May 10, 2002 | 07:16 PM
Mike D.'s Avatar
Mike D.
Banned
Basic performance upgrades and advanced perfomance upgrades. BPU would be basic upgrades where APU would be,
single or upgradede twin turbos. Btw, I would never put an Unorthadox underdrive pulley on my car. They do however, make great cam gears and pulleys for the rest of the engine. I know, I have them on my Supra.
Old May 22, 2002 | 08:14 PM
TRDGS3's Avatar
TRDGS3
What I have been told is that the Unorthodox Cam Gear (exhust side only) is ok for any car...the pully kit (race version) is no good...however....if you go with the light pully kit it is just like stock only lighter it is ok....it uses your stock belts and everything else
Old May 27, 2002 | 07:05 AM
v300's Avatar
v300
I wouldn't use the race pulley for belt and alternator reasons. I used the street (same diameter size as factory) before with good results.
Old May 31, 2002 | 12:59 PM
LexusL's Avatar
LexusL
Thanks for the info it been kinda helpfull, Yeah I also heard that the pullys are not good for your car throughout CL forums but I never heard anything about the cam gears.
wenger828
May 9, 2004 08:16 PM
Pianoman72
GS - 1st Gen (1993-1997)
13
Mar 30, 2004 11:56 AM
therriott15
Jan 9, 2003 02:37 AM
IS2000
Performance
Mar 5, 2002 07:24 AM
1NICESC430
Oct 25, 2001 11:34 AM
