No catalyic converter???
Old Apr 22, 2009 | 11:22 AM
al-ex-us's Avatar
al-ex-us
Default No catalyic converter???
Has anyone driven a GS4 without a catalyic converter? If so, how noisy is it? If I put a Blitz exhaust system with pre-silencers on it, would it be even louder? Thoughts and suggestions, please.
Old Apr 22, 2009 | 05:52 PM
VIPFAMILY's Avatar
VIPFAMILY
I am dumb and basically unbolted the exhaust right in front of the third cat sooo basically running nothing after the headers and it was pretty loud a little raspy not bad full throttle the thing was scary but could tell a big difference at low rpm .......in a bad way .... Dunno if that helps
Old Apr 22, 2009 | 07:06 PM
vwynn's Avatar
vwynn
search up exhaust...
its called adding an X-pipe to remove the cats. also the cats only filter out the fumes not noise... If you want increase exhaust note you would want to remove the resonators..
Old Apr 22, 2009 | 07:57 PM
GSteg's Avatar
GSteg
I hope you mean resonator and not catalytic converter :P
Old Apr 22, 2009 | 10:11 PM
al-ex-us's Avatar
al-ex-us
What's the outcome for each scenario?
Old Apr 22, 2009 | 11:33 PM
farquad's Avatar
farquad
i removed the resonators in my 91LS and welded some magnaflow tips on.. the sound is stock on idle, but when i give it gas it sounds some what like a stock G35.. not a bad sound at all, but it's no where near after market exhaust loud, if you were to add some a/m exhausts on top of removing the resonators, i'd say it would be pretty loud
if you removed the cat, you probably won't pass your emission test
Tom2769
IS F (2008-2014)
31
Apr 15, 2024 01:05 PM
Sylexus
Oct 31, 2013 05:19 AM
chi123
Oct 20, 2012 12:47 AM
carlos
Performance
Jul 17, 2007 01:53 PM
GRIFFEN
Mar 30, 2004 05:09 PM
