SS Headers input, question
Old Mar 6, 2009 | 09:37 PM
  #91
tom steele's Avatar
tom steele
why cant they make some in stainless and just charge more for the material the labor is the same i don't get why they just don't make them in stainless as an option for us picky people seems it would take care of the bad pr at least
Old Mar 6, 2009 | 10:09 PM
  #92
tom steele's Avatar
tom steele
i sent an email to s@s to see if they will do a lot of twenty in stainless for us picky people we will see what they say worth a try right or has some one already ask them to do this upgrade just wandering
Old Mar 6, 2009 | 10:30 PM
  #93
sam430's Avatar
sam430
Yeah...I never asked that question (steel). Also, question on the bolts...why is it not recommended? What bolt is recommended (gotta find out before next Saturday)? I've seen the gasket... I just tossed it in the trash.
Old Mar 7, 2009 | 08:34 AM
  #94
tom steele's Avatar
tom steele
just me but i would just use some grade 8 bolts from your local hardware store remember its metric also use some antiseize on the bolts i would take a old bolt out to compare to make sure you get the right thread pitch
Old Mar 7, 2009 | 09:00 AM
  #95
JBrady's Avatar
JBrady
Yes, I had the conversation with S&S about stainless.
Stainless labor is not the same. Harder to cut, intersections need to be very precise for proper welding, backpurging is needed for proper welding, welding is harder and requires more time and stainless expertise and of course materials are more expensive.
Again, with all the labor intensive requirements there is a huge advantage to any foreign (China) source with nearly free labor.
S&S has been building headers for decades. Always mild steel. They are not set up for stainless in either materials or procedures. Getting a company to change what they do is unlikely. That said without S&S there would be no headers for our cars. The price makes them the least expensive power per dollar option for our cars. I would love stainless but the ceramic coating will make the mild last for longer than most will own their car.
Re-use the OEM bolts and studs at the heads. The supplied bolts for the cat flange work. Use OEM gaskets.
Old Mar 7, 2009 | 11:32 AM
  #96
sam430's Avatar
sam430
I bought new oem gasket...can I double up on it if the existing gasket is in good condition to help prevent leaks? I assume the O-Ring at the flange cannot double up...but I don't know for sure.
Old Mar 7, 2009 | 11:37 AM
  #97
GSteg's Avatar
GSteg
No. Never double up on gaskets. You can introduce leaks that way.
Old Mar 7, 2009 | 11:51 AM
  #98
sam430's Avatar
sam430
Thanks. Although it would make sense that when it's doubled up and compressed..it would seal much better...then again..I never took apart the GS. Ok, I will ask the guy to clean the area.
SAUD
Performance
29
Aug 2, 2019 09:00 AM
rmillsISF
IS F (2008-2014)
May 8, 2016 06:41 AM
LexFlexTex
Nov 23, 2015 02:20 PM
btorok
Performance
Jan 12, 2007 09:18 PM
onebadshot
Sep 9, 2006 01:11 PM
