Lexus IS350 06-07 Prostreet S/C Kit
Old Sep 22, 2008 | 07:03 PM
  #121
Zexnos's Avatar
Zexnos
This is the only dynojet plot i have discovered thus far. I do not know why the base numbers are low. This is on a 2006 IS 350 with the Greddy axle back.
Base: HP 246 TQ 223
SC: HP 309 TQ 269
Old Sep 22, 2008 | 07:08 PM
  #122
caymandive's Avatar
caymandive
11 Second Club
That baseline is definitely low. Those of you with superchargers I'm not sure whats holding you guys back from doing a bit of research and testing on your cars. I know if I had spent the money and all the time on a S/C I would sure the heck want to see my net results.
Old Sep 22, 2008 | 07:29 PM
  #123
KMRIS350's Avatar
KMRIS350
1st time on youtube! Here is a small vid of my BOV I installed today.
http://www.youtube.com/watch?v=5MU9q0JbHXU
Old Sep 22, 2008 | 07:33 PM
  #124
KMRIS350's Avatar
KMRIS350
Im still working out a couple issues "boost leak" but I will get her on the dyno soon as possible.
PS- Congrats on the new ride!
Old Sep 22, 2008 | 07:50 PM
  #125
dat-is350's Avatar
dat-is350
The blow off valve sounds a lot better than before. Can't wait to see numbers when the SC is working normally.
Old Sep 22, 2008 | 08:44 PM
  #126
iSuxeL's Avatar
iSuxeL
I will post numbers as soon as I get money to add a few more parts
Hey Keoni, is that the BOV you were talking about? I've been busy at work and could not find time to work on my BOV.
Old Sep 22, 2008 | 09:06 PM
  #127
Sytfu_IS's Avatar
Sytfu_IS
I wonder if doug had this problem when he had the sc and how a hks bov makes it lose pressure
Old Sep 22, 2008 | 09:08 PM
  #128
iSuxeL's Avatar
iSuxeL
Its not the BOV, its the spring inside. We need to get a stiffer spring, cause these BOV's are made for high boost, therefore its not holding boost.
Old Sep 22, 2008 | 09:18 PM
  #129
Sytfu_IS's Avatar
Sytfu_IS
ohhhhh, GL with fixing everything
Old Sep 22, 2008 | 10:22 PM
  #130
KMRIS350's Avatar
KMRIS350
I took one of the HKS BOVs apart tonight and it has a torn bladder. Could explain the boot leak But I still think its not a good match for our application with the stock spring. Im not sure if it needs to be stiffer or not. I have 2 and I swiped a 3rd today just to test while I had the nose off the car and all of them fluttered when releasing pressure. Crap I should have ran the video! I know for a fact the one I swiped works great on my friends car "I think he is boostin 18-20". Im giving him all of of them! Im over it! Ill stick with the Synapse Synchronic BOV! Boost and swoosh!
Old Sep 22, 2008 | 10:35 PM
  #131
Sytfu_IS's Avatar
Sytfu_IS
No lost of pressure at all with the synchronic one? Awwww no more psshhh flutter flutter sound hahaha
Old Sep 22, 2008 | 10:39 PM
  #132
2slow's Avatar
2slow
This one sounds so much better!!!!! I like it!
+1 for Synapse Synchronic BOV
Old Sep 22, 2008 | 10:48 PM
  #133
pylee257's Avatar
pylee257
can someone run me by as to why this kit would not work on the IS250?
Old Sep 22, 2008 | 11:06 PM
  #134
2k2 R1's Avatar
2k2 R1
I'm sure it would work if the brackets were modified
Old Sep 22, 2008 | 11:21 PM
  #135
pylee257's Avatar
pylee257
last i heard from LMS..that this kit would work for both 250 and 350. maby that was a misconception. would there be extensive modification to the kit in order to make it work?
