Lexus IS350 06-07 Prostreet S/C Kit
The belt is still slipping pretty bad in 3rd and 4th so theres no point in track/dyno time yet. Once it gets figured out then we'll see. I can't wait for this weekend cause I get my Synchronic!!!!
Was there boost leak when lms was dyno this kit and claimed a what 40-50whp gain? Was there belt slippage too? What's causing this belt slip
I've heard the goodyear gator belt is better than a regular serpentine one.
Get a boost gauge yet?
Yes I got my boost gauge on and I should be a lot faster than I am now for sure and I mean a lot. There isnt a smaller size belt I'm currently running a 28.8, if I could find a 28 or even a 27.8 it'll be perfect. You are correct about not having enough wrap on the SC, if you know of a place that has a smaller belt please LMK.
As of now the only solution I have is to run the pulley that came with the SC, which is bigger than the one I have, the previous owner put a smaller belt for more boost. But with a smaller pulley you need a smaller belt.
I checked the 3 belt companies Goodyear,gates and Dayco and 28.8 is the smallest they make so maybe some other brand?
It is part number 582K5
I could not remember how many ribs the pulley has so I guessed 5, you might need to check again if that is incorrect.
