Installing Odyssey PC680T lightweight battery
I have a buddy of mine coming over tomorrow who used to work for a speed shop, so we'll see what he thinks. He is pretty good at welding, so we may have more options than what I posted.
Have you actually connected the battery yet to see how easily it will start the car? I would have bought one long ago if I knew it would crank the motor and maintain a charge for 3 days without being driven. I loved the PC680MJT in my S2000, but it didn't have nearly as many electro-widgets.
So we did our test fitting this evening and only have a few minor things to change about the design. The change will be to tack weld the bolts onto the flat bar to make installation very easy. We found that it's a PIA to hold the bolts in place from the rear while tightening from the front. If we just weld the bolts into place then all we have to do is slide the battery cover onto them and bolt it up with the nylocks. The plan is to do the welds tomorrow and I'll drive around for several weeks to see how it works out. I'm not expecting any issues.
PS..Many thanks to board member TYWRAP (Jon) for the design and custom mounting bracket. Once this thing is completed I'll have to name it in some way after him. Maybe the JP Mount.
Here are the pictures.
i dont know about this certain model but when i had those oddysey batteries on my s13, they would last around 10months till u start experiencing problems with maintaining charge. my friends had these problems also with these "type" of batteries, iono whether its because its (gel cells) instead of the norm.
TYWRAP who drives a Supra has had his 680T for several years as well with no problems.
For weights this is what I have noted so far and I will edit when I get solid numbers.
OEM battery - 42.5 lbs
OEM Hold down hardware - .5 (approx)
Odyssey battery - 16 lbs (including the black aluminum hold down box)
JP Mounting bracket- 7.7 oz or .48 lbs
Approximate weight savings is 26.5lbs
Plus I'm getting a bit tired of all the intake, exhaust and wheel threads and wanted to do something different.
Good luck let us know what you did.
