Supra TT LSD into an '01 gs430
First off, Do I need the one from an auto or 6 speed supra? Is this a direct swap? Do I need the whole pumpkin or can I just swap out the internals and put in the supra lsd unit into my pumpkin? thanks guys
also, Is there any way to make our trannies shift firmer? Any companies out there make shift kits?
It's a direct swap. The one you want is the supra auto tt differential.
Swapping out internal will require a lot more work than swapping the whole pumpkin. Even then, I dont know if you can swap the internals.
For a firmer shift, I believe SRT has a valve body upgrade.
there is someone here that changed the LSD guts from the supra to the GS, so it can be done. however just swaping the LSD alone should work too, but i have not done this, so don't know. if you look in the TRD website, the supra has the same LSD part number as our cars, so maybe they can be swaped.
here is a link to a LSD for sale. this is alot cheaper than buying the TRD like i did.
http://www.supraforums.com/forum/sho...d.php?t=450032
also, this way you can keep your stock gear ration.
Yeah, I had a new (3.76 LSD) unit installed recently on my GS400 and it's great! I'm also one of those lucky ones that do not hit the rev limiter!
I was one of the ones that bought one off eBay. Call Johnny at Titan Motorsports. He may get some more in.
