Strange rattle noise during acceleration
Old Aug 13, 2007 | 04:03 PM
darchard's Avatar
darchard
Question Strange rattle noise during acceleration
I posted about a three weeks ago with the same problem. Took it to the dealer, drove with the technician and the diagnosis was the mufflers. Lexus felt there was debris within the muffler. They were both replaced under the warrentee. The noise really never disapeared. It is very evident going uphill. Was not there during a recent rainfall....pretty weird. Anyone have any ideas?
Old Aug 13, 2007 | 06:02 PM
LEXTEK444's Avatar
LEXTEK444
I had a oddball suspension rattle(i know it was under accel but the suspension squats so it could be) that ended up being lack of lubrication for the sway bar bushings. This could be the case because water can act as a very temporary lube. Also is it coming from the rear or the front. Also is it from full throttle or half throttle. Any info will help
Let me know, Allen
Old Aug 14, 2007 | 03:52 AM
darchard's Avatar
darchard
Allen,
It is comming from the front. Low to about 3k rpm. It's not loud but noticable. I intially thought it was a belt. The tech drove it with me and opened the door during acceleration and thought it was the muffler. It almost sounds like knocking. I use premimum gas. Thanks.
Old Aug 15, 2007 | 11:26 PM
macd7919's Avatar
macd7919
Can you feel the rattle in the car or just hear it?
Have you check all your heat shields for the exhaust?
If one is touching the exhaust you can just take a broom handle and bend it back up, if it's loose just tighten the mounting points with a wrench.
Old Aug 16, 2007 | 01:27 AM
Kaluna's Avatar
Kaluna
One of the rattles I had was due to a heat shield. I used a constant torque clamp from a diesel charge air cooler. Wrapped it around the heatshield & exhaust tughtened it up... no more rattle. Mine would rattle from around 1000rpm to 2300. Might be worth a shot.
Old Aug 17, 2007 | 12:24 PM
darchard's Avatar
darchard
Thumbs up Right on the money
Took my GS in for service call to attempt to fix the rattle. Adjustments were made to the heat shield. The rattle is gone. Great call!!!!!
Old Aug 19, 2007 | 11:05 PM
#1gs300's Avatar
#1gs300
GLADE U GOT RID OF THAT ANNOYING SOUND
igzy
Aug 30, 2018 12:20 PM
Mervinbill
Nov 10, 2017 01:15 PM
peasodos
Nov 3, 2017 12:49 PM
kengtay
Jan 25, 2003 11:44 AM
