How to get some extra power
my 89 Supra spare tire 125/90/16 weight 24.4lbs
my 99 GS400 Full size comes with Stock alloy weight 47.8lbs
btw GS FONZy
1. Do you or Have you ever really been at the track? really.
2. Do you even have or use a lighter spare tire? Have you weighed anything for the purposes of track use? Have you ever Weighed a spare tire 17 or 16?
Do you have a supra spare tire?
3. Do you understand Rotational Inertia?
4. Do you understand Power to Weight Ratio?
please if you have been or are well versed at the track then you would understand all 13 Tips that I have provided to SFGS. He doesn't seem to be in the category of understanding the benefits of an "external wastegate, Big20G, with a modded flapper..etc."
He has a GS300 it will be tough to gain 30HP without a turbo or SC.
the only way to give him power to weight advatage is to lower his weight.
1. Run down the street with nothing in your hands.
2. Now run down the street with your Floor mats, Full size spare tire, the Metal Jack/metal 19mm wrench, and a Barry Manilow CD on your back.
Tell me which time will be fastest.
at the track I run a 2G DSM Talon Turbo AWD 16G ported 34mm flapper I know about turbos. $30 1gBOV crushed + $8 Manual Boost Controller at 9 psi of boost = 13.85
I did remove 1 Barry Manilow CD, 4 Floor mats, 1 Full Size spare tire, 1 Metal jack/wrench. Best $38 ever spent.
Btw GS FONZy
Please continue to discuss the 13 low budget tips that I have provided for SFGS.
not once did he mention hitting the track. yes, i have hit the track before and no i don't gut my car just to gain a tenth of a second. i can show you my time slips if you want
for track use; removing spare, jack, ect... does makes sence, but once again not relevant here and you realy don't help your ETs by that much just removing spare, jack and a 3oz CD
you must shave 100lb or gain about 15-30hp to drop about a 10th of your ET. Oh yeah, i have a spare tt wheel and it feels a lot heavier than my stock 16
maybe because it's steel. my spare tt weighs 38lbs btw, how is removing stuff from your car be the best $38 spent
Trust me...I know!
I believe in doing it right the first time. I kept having an itch to do headers and SRT intake when I was still NA, but I'm glad that I didnt. I mean whats the point of doing all these NA mods when you're eventually going to upgrade anyway? You're kinda shooting yourself in the foot because most of the NA mods will be useless once you boost.
Then again most people aren't looking to make big power...so if that's you then disregard my post
Bang for the buck you wont beat the Srt intake for hp gains (roughly $450 shipped). Next best mod (but quite a bit more $$$) would be to do a Precision torque convertor, that will make big gains in acceleration but it's alot more than the intake (roughly 900 for the convertor then another 200-300 for installation)
Btw- I would do a thourough search about torquemaster plugs before I put them in my car. Do yourself a favor and google them, you will find many people who have had bad experiences with them as well as a number of them disintigrating and destroying peoples engines. Your best bet would be going with a proven plug like the Denso or Ngk Iridium.
My advice: Drop some current weight in the car.
2. It would be on the High$$ side for him to go the route of boost.
My advice: Get his car running in the best shape possible (fluids, etc)+
CAI + Exhaust + NGKs + light weight rims = better performance.
SFGS needed some advice on performance. He can do some searches on the topics that I have discussed and come to some conclusions and choices.
or listen to posts from guys like GS FONZy that shoot in and make wise cracks about other peoples intention to help you out in the forum.
2. CAI...SRT...check the GS for sale posts
3. New Exhaust: Apexi WSII,Tanabe, Carson Tuned...Borla is nice...
4. Remove your Full size spare IF YOU WISH
5. Take out all needless weight in the car IF YOU WISH
6. Tranny Flush (not drain and fill) the Full Tranny Flush Toyota Type IV
7. Rear Diff fluid change...DIY bannana GS website...if available
8. Royal Purple or Amsoil
9. Throttle boddy cleaning...(2.99 can of heaven)
10. BG44K in the tank
11. Fresh set of plugs
12. 225/50/16s lower profile+light weight tires 20-22 lbs,(load rating 91-94)
13. Braille light weight battery
I have edited tips #4 and #5 because of the helpful information provided by GS FONzy.
good luck SFGS
the spare tire comment, i completly for got about the mkiii. since mkvi has the same spare wheel for both NA and TT, i thought that's what you were talking about. like i said this wheel weighs 38lbs and feels heavier than my stock 16.
throw in some HID lows and fogs and you'll cut down your power consumption to 140 total.
good luck.
