IS 350 Supercharger
Old Apr 11, 2007 | 12:59 AM
  #91
ddquach's Avatar
ddquach
If I'm not mistaking RoRo, your problem probably like mines. Its trying to hook up the tires because I spin my tires in 1st to 2nd gear. That's why the times are so bad.
Old Apr 11, 2007 | 03:21 AM
  #92
RoRo's Avatar
RoRo
I was launching just fine with the drag radials. I don't have any fuel tuning whatsoever except for this sensor that LMS installed that listens for knocking and if it detects it, then it cuts back on the timing. When my supercharger stopped working, I sent it in to Procharger and they replaced it for free, but I had them put on a smaller pulley to run more boost and now I need to have it properly tuned.
I'll be taking it out today. I haven't driven it in over a week.
Old Apr 11, 2007 | 03:38 AM
  #93
GILLEXUS's Avatar
GILLEXUS
Originally Posted by RoRo
The current state of my IS that it does pull much harder then when I had the larger pulley on it. I finally got the correct belt on it and it's running fine. I need to get it into a shop to have it properly tuned though because I took it to the drag strip and I could not beat my times from when it was stock. It just felt like mid-track the power was cutting back or something at the drag strip. I can't and won't be able to explain it until I get the car to a dyno or a shop to get it properly tuned. I know that it is much faster than stock and much faster then when it had the larger pulley on it, but I don't have the times or dyno sheet to show for it as of yet. My last dyno was with the larger pulley and it was 314 at the wheels. My stock dyno was 268 at the wheels.
RoRo what boost were you at with the larger pulley? and now w/ the smaller one?
Just a thought, since the S/C is running off the stock ECU maybe w/ the increased smaller pulley boost, your leaning out and/or the ECU is slightly retarding your timing.
I'm not sure how much you are going to be able to tune it on the dyno unless you have some type of FMU or piggy back>
Old Apr 11, 2007 | 08:13 AM
  #94
Gernby's Avatar
Gernby
Roro, I just noticed the "Fastest Known IS350 in 1/4 Mile" under your name. I think I may have to claim that title! At least until you get things worked out and take the title back...
Old Apr 11, 2007 | 08:49 AM
  #95
RoRo's Avatar
RoRo
It's all yours bro. I don't put those labels there though, so you'd have to contact an admin or something. Hopefully, when I do take it back it'll be by more than 5/100ths of a second.
My 100th post....Yay for me.!!
Old Apr 11, 2007 | 09:20 AM
  #96
Gernby's Avatar
Gernby
Hopefully it will be by at least .095 seconds! Somebody's gotta brake the 13 second ceiling...
Old Apr 15, 2007 | 08:15 AM
  #97
NORCAL SS's Avatar
NORCAL SS
are they using a roots blower or other design. i have a magnacharger on my trailblazer ss and stock is 400 but now im doing over 550hp at wheels and 570tq with a few other mods. Roots will give you instant boost and torque no lag.
www.myspace.com/sstrailblazer
and heres a vid 0-100 this is in a 4600 pound suv
Old Apr 15, 2007 | 11:29 AM
  #98
Gernby's Avatar
Gernby
Is it even possible for a roots style blower to have an IC l
Old Apr 15, 2007 | 12:02 PM
  #99
NORCAL SS's Avatar
NORCAL SS
my kit is intercooled and yes roots blowers have intercooler set ups just look at the lightning.
since the car is such a small motor the roots will give instant torque right off the line no lag like centrif. blowers.
Old Apr 15, 2007 | 12:13 PM
  #100
Gernby's Avatar
Gernby
Come to think of it, I have seen aftermarket roots style blowers with air to air ICs (hot side on I4s), but I don't know how a similar design could be done on a V6 with such a cramped engine compartment..
Old Apr 15, 2007 | 12:17 PM
  #101
lobuxracer's Avatar
lobuxracer
Tech Resource
The argument against Roots blowers is their inefficiency. They have the worst efficiency of all blower styles. Centrifugal is best and Whipple is between Roots and centrifugal.
Old Apr 15, 2007 | 12:39 PM
  #102
Gernby's Avatar
Gernby
Has anyone ever tried implementing a centrifugal with a continuously variable pulley system?
Old Apr 16, 2007 | 10:55 AM
  #103
Tmirk's Avatar
Tmirk
The tom's kit appears to be a roots or twin screw/whipple type.
Old Apr 16, 2007 | 12:43 PM
  #104
lobuxracer's Avatar
lobuxracer
Tech Resource
You'd be better off designing a CVT for one. They really need a constant speed on the output because just like a turbo, they'll go into surge if you overspeed them, and we all know surge is BAD. The problem is, you need an output speed around 100k rpm, with an input speed of only a few k rpm.
Old Apr 16, 2007 | 02:38 PM
  #105
NORCAL SS's Avatar
NORCAL SS
ROOTS Worst lol umm ok well works on my truck perfect and putting over 580rwhp out on pump gas
