VDIM fundamentals -- Think you know??
Old Apr 8, 2007 | 07:33 PM
CoasterG's Avatar
CoasterG
Ouch.
(Enough said)
Too rich for my blood but thanks Lobux for taking the time and effort to find the answer. Now we know however that it can be done.
Out of curiousity, any other benefits of installing a 2007 ECU? And would an ECU from a junked IS350 be feasible (and cheaper hopefully)?
Old Apr 8, 2007 | 07:35 PM
caymandive's Avatar
caymandive
11 Second Club
It takes about 5 minutes to do the swap if you work slowly. You only need a 10mm socket on a short extension to remove the three screws holding in the skid control ECU. Everything else snaps apart/together.
The new ECU lists for $1492.94. It actually costs more than the engine ECM.
All of a sudden I'm liking the pedal dance.
Old Apr 8, 2007 | 07:36 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
No other known benefits. Yes, the ECU from an irreparable total would be fine. It is extremely unlikely this ECU would ever be damaged in an accident, unless the passenger's knee airbag were to cause the support to smash into the ECU, but from the positioning, it looks pretty unlikely.
Most of the dismantlers I know charge half of MSRP for ECUs.
Old Apr 8, 2007 | 07:37 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Keep in mind, if anything goes wrong with your skid control ECU, this ECU will be installed to replace it. Food for thought.
Old Apr 8, 2007 | 07:40 PM
caymandive's Avatar
caymandive
11 Second Club
Thanks Lobux. You definitely provided some great information in this thread. I'll keep this post in mind. hehe
Old Apr 9, 2007 | 12:23 PM
phatboyc's Avatar
phatboyc
Thanks for the info Lobux.
For the few times I need it off Ill keep on dancing.
Old Apr 9, 2007 | 02:18 PM
ba-b4's Avatar
ba-b4
wasn't someone working on a switch for the 06's? did that project ever work out?
lobuxracer's Avatar
lobuxracer
Tech Resource
Yeah, but the inventor decided to drop it after he found out the only market was going to be for the '06s. There's a thread on it somewhere around here.
Old Apr 10, 2007 | 02:43 PM
Gernby's Avatar
Gernby
If I thought there was enough demand for it, I would make for less than $100 using a small microcontroller to simulate the pedal dance at startup.
Old Apr 10, 2007 | 02:45 PM
Gernby's Avatar
Gernby
BTW, I thought seriously about doing 18's in the front, and 19's in the rear. It shouldn't give VDIM any problems at all since the OEM rear tires are already 1" taller than the OEM fronts. If you get the right tire sizes, that 1" difference in height could be entirely wheel, instead of rediculously tall sidewalls like the OEM rear tires have.
Old Apr 11, 2007 | 11:54 AM
IS350jet's Avatar
IS350jet
The car will not beep at you constantly no matter how staggered your setup is. The beeping that you hear has nothing to do with traction control. You will only hear the beep when the car enters a skid, period. Simply, if you hear the beep, the car is not traveling in the direction its pointed. The VSC computer is able to detect a skid because it receives a signal from the yaw-rate sensor which is located in the exact center of the vehicle. There's no way you will ever hear the beep unless the car is over/under-steering.
Old Apr 19, 2007 | 09:39 AM
ahohnstein's Avatar
ahohnstein
Originally Posted by 2IS808
I got a question for anyone who thinks they can answer a very technical problem.. . I know for the 07 2IS u can turn VDIM (traction control??) on/off with a switch. Which would make this conversion so much easier. However I was badass enough to get a 2IS in 05 (yea right...)... which means i got the 06 version. Heres where i need some help.. I was thinking to myself.. Damm i wanna be ganster and run 19x9's in the front and 20's x10.5 in the rear.. If the tire rotation of the front wheels differes from that of the rear wheels; will it cause the traction control to constantly beep at me like when your tires slip (since its registering as different rotation ratio's)? The left and right sides will be in sync.. just not the front and rear.. So I guess my question is where VDIM takes it's measurements.. From the front tires vs. the rear tires?? or if the rear left tire differs from the rear right tire?? Any technical advise would be greatefully appreciated. Thanks --
If you're familiar with a bicycle speed sensor (magnet attached to spoke, rotates around and triggers a sensor on the stay) I believe it acts sort of like that. But the TPM senser acts as the magnet (or vice versa) and there is a stationary sensor inside the wheel well. If you increase the diameter of your wheels but still have the TPM sensor installed VDIM will accommodate since the diameter of the wheel and speed of rotation is used to calculate speed.
Of course, this is pure speculation but I thought I remembered reading something about a sensor mounted underneath by the wheel well when perusing the techinfo.toyota.com documents.
Old Apr 19, 2007 | 12:28 PM
Gernby's Avatar
Gernby
The speed sensors are on the hubs, not the wheels, and the sensors doen't just count the number of rull rotations like the bicycle sensor you speek of. It would be more like having a separate magnet on each spoke of the bicycle wheel so it could calculate speed with extreme precision.
However, that still doesn't change the fact that extreme changes in outer tire diameter will effect VDIM.
Old Apr 20, 2007 | 05:26 PM
IS350PRO's Avatar
IS350PRO
I would love to be enlightened as to how to perform the infamous pedal dance. I have never heard of it and the biggest complaint I have with my 06 IS350 is the fact that I can't get the car to drift. Educate me, someone, anyone, help me get sideways.
Old Apr 21, 2007 | 02:06 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
It's in the FAQ.
