wideband sensor
Old Jan 25, 2007 | 06:15 PM
GS FONZy's Avatar
GS FONZy
Default wideband sensor
anyone here using a wideband o2 on a GS4? where did you put the o2 sensor?
from what i have read they should be close to header. do we need two or is one good down where the Y pipe is? any feed back would help.
Old Jan 25, 2007 | 06:19 PM
bigL's Avatar
bigL
Dont know but Im curious too.What wideband are you using?
Old Jan 26, 2007 | 12:35 AM
macd7919's Avatar
macd7919
If you want to run just one Wideband (what I would do) I would mount it near one of the collectors on either bank. It will only read from the bank of the collector you are mounting it near but this should be fine (both banks will be in the same general A/F reading). If you are running a FI setup than you *may* want to run a sensor on each downpipe close to the exhaust of the turbo's to help monitor for any fuel issues (just for safety) as boost + lack of fuel could lead to a blown motor.
Old Jan 27, 2007 | 10:03 PM
GS FONZy's Avatar
GS FONZy
non FI gs4 runnig widebands?
Old Jan 28, 2007 | 04:32 PM
macd7919's Avatar
macd7919
See above..This part is for Na. The other part "If you are running an FI setup....." is for turbo.
usoff89
Sep 27, 2013 02:31 PM
HumphreySC
Jul 27, 2013 10:49 AM
martshap
Jul 8, 2009 04:26 PM
Ranger-CPT
RX - 1st Gen (1999-2003)
Jul 31, 2006 06:08 PM
VSsc400
Jun 19, 2003 05:04 AM
