LS400 engine compatible with GS400???
QUESTION: Can I install an engine from an LS400 into a GS400? If so, what components need to be kept from the GS? Is this advisable?
Yep, 2 nights ago, my 1999 GS400 with 125k miles died catastrophically...don't know why. If my photo attachment works, you will note the connecting rod that is through the engine block above the engine mount on the driver's side. Quite dramatic? Oil is fine...same thing I've always done. I drive the car very hard...and this blew about 6k RPMs in 2nd gear....hmm...no clue.
But, I plan to keep this car....still everything I would ever want in a car (based on my budget!)...so, no problem...except...
Having trouble finding an engine to replace it with. I do have a bid, but the engine is supposedly coming from a 1999 LS400....I think those long blocks are the same...but know nothing else. Can an LS engine simply be dropped into my GS...or are there seveal components from the GS that need to be removed and put on the LS engine?!?!
Any help would be great.....thanks.
So, the long blocks of the 1999 LS400 and GS400 would interchange, but anyone planning on using an LS400 engine in a GS400 needs to plan to refit the GS intake assembly (manifold, fuel, computer, etc) onto the block/heads of the LS engine?--as well as the other items you mentioned.
...i.e., certainly not just a drop-in?
The VAST majority of used engines available are from early model LS and SC400s from years 1990-1997... those are not advisable as replacement for MANY reasons.
As for the reason for the failure... do you know yet? Was the timing belt replaced on this motor around 90k miles? Had a friend years ago loose his Infiniti Q45 engine when his tensioners failed and timing chain jumped. Pistons hit valves, rod(s) broke and punched through the block. His happened during cruise at 60mph.
As for reason of failure, I do not know yet. There might be more damage...haven't opened her up yet. Yes, timing belt was replaced around 91k miles. Oil usually changed about 3500-4500 miles. Last oil change was 1015 miles ago.
