Closed Loop A/F for FI
Old Dec 31, 2006 | 08:02 AM
BurgandyGS's Avatar
BurgandyGS
Default Closed Loop A/F for FI
Just wondering if any of you FI guys that are not running a maf, have any issues with your a/f under closed loop. Seems to me that the ecu is constantly adjusting and fighting my piggy-back unit. I know these OBD2 cars are a pain to tune and you need a lot of dyno time to properly do it. Obviously, if you have a full standalone, this doesn't apply.
Old Dec 31, 2006 | 10:19 AM
JPI Racing's Avatar
JPI Racing
What piggyback are you running? You have to keep this in mind. The stock ECU will try to keep the A/F in 14.7 range. Your close loop A/F will be determine on a couple of things: o2 sensor, coolant temp etc. Stock ECU will look at the 02 very closely and make the adjust from there.
JP Importz
Old Dec 31, 2006 | 03:59 PM
mikal's Avatar
mikal
JP Importz
He's using a Map-ECU with his 2jz-gte VVTI ecu.
Old Jan 1, 2007 | 01:07 PM
BurgandyGS's Avatar
BurgandyGS
correct It is a great unit. You just need some fine tuning. They have a new map-ecu2 coming out in late January. It has a O2 simulator signal map to trick the ecu. Specifically for OBD2 cars and this situation. I just don't want to buy another unit. I know it will work, you just have to find a median a/f. They are using them on Supra's and IS 300's all day. I think we got it real close yesterday. Also, when you change the injector size to 850cc like I did, your voltage needs to change too. We found that the maf was sending out a voltage of like 270 and that needs to almost double for startup to be optimum.
Old Jan 2, 2007 | 06:57 AM
GSoup's Avatar
GSoup
CL Folding 10,000
Maybe a SplitSecond ESC1 may help with the closed loop situation.
http://www.splitsec.com/
Scuper300
Feb 5, 2015 09:14 AM
kauaian
IS F (2008-2014)
May 23, 2013 05:33 PM
genefury
Feb 20, 2013 11:05 PM
vwynn
Performance
34
Apr 18, 2012 05:30 AM
LOTC
Mar 27, 2001 09:29 PM
