Fuel rail question
Old Dec 25, 2006 | 12:36 PM
morris's Avatar
morris
Default Fuel rail question
Hey do you know what size the supply fitting is on the fuel rail of a GS400, it looks like I am going to make some changes to the fuel system. I need to know if the rails are NPT or metric and what size?
Anyone?
Old Dec 25, 2006 | 06:45 PM
JPI Racing's Avatar
JPI Racing
Hey Morris,
What are you planning to do? Are you running a bigger line? It's a fine thread, I will check on the size tomorrow.
JP Importz
Old Dec 25, 2006 | 07:13 PM
morris's Avatar
morris
Well I am still working out the details, I may add a second pump. But at a minimum I am going to use the -6 for the supply and then use the stock liine for the return.
Right now I am using the stock line to supply the rail.
So if I am going to run the -6 supply I need to be able to plumb the -6 into the rails. I really dont want to have to drill and tap the rail unless I absolutely have to.
The end caps were metric, and I am guessing that the supply fitting on the rail is metric also. If so I am out of luck and will have to drill and tap it for a NPT fitting so that I can use a AN to NPT on the rail to hook up the supply from the y block.
This is all becasue I seem to be getting inconsistent fuel pressure, as I start moving from vacume towards boost my fuel pressure on the rail starts to drop off when it should be increasing.
I am guessing that the problem is that the walbro isnt able to supply enough pressure. If it was a volume issue my guess is that the psi would fall close to zero.
OR something in the tank is hosed up.
Either way I am going to have to open things up and I dont want to have to do that again so I may just try to address everything at one time.
I am at 45psi at idle, as I accelerate it sometimes drops as low as 35psi when it should be increasing.
Another option would be to install a booster pump and see if that solves the problem. But I am leaning away from this option right now.
Old Dec 25, 2006 | 07:48 PM
Supraownzu's Avatar
Supraownzu
not saying it would be the easiest option, but you could always just weld a fitting on the ends of the rails instead of doing a fitting. i had to have that done since my rail ended up right at the firewall and a straight fitting wouldnt have fit.
Old Dec 25, 2006 | 07:56 PM
morris's Avatar
morris
yea thats a thought I read about someone doing that over on dot net. They even had the bungs at summitracing. My only concern is that I dont have anyone that could weld aluminum. Isnt that a special welding machine that is needed for aluminum?
Old Dec 26, 2006 | 06:31 AM
JPI Racing's Avatar
JPI Racing
Default Fuel Pressure
Are you running the returnless fuel system? If you are, I would get the BEGI rising rating regulator. It will raise 7 pounds of fuel pressure for 1 pound of boost. Also here is a quick chart for injectors calculation:
Flow Rate= (HP x BSFC) / (#Injectors x Maxcycle)
Let me know if I can help
JP Importz
Old Dec 26, 2006 | 07:43 AM
morris's Avatar
morris
nope I have a return line in but I am using the aeromotive fpr, which is 1:1. If you come across what size the fittings are on the rail that would be tons of help.
Thanks
Old Dec 26, 2006 | 10:41 AM
JPI Racing's Avatar
JPI Racing
The size is M12x 1.12
JP Importz
Old Dec 26, 2006 | 12:04 PM
morris's Avatar
morris
Well it looks like good news Summit has -6AN to Metric 12mm adapters, both in 1.5 pitch and 1.25 pitch. My guess is that one of those is gonna be the right thread.
Old Dec 26, 2006 | 12:52 PM
JPI Racing's Avatar
JPI Racing
Or you can weld it. Send us the rail and we will weld it for ya .
JPI
Old Dec 26, 2006 | 07:59 PM
Supraownzu's Avatar
Supraownzu
you just gotta find someone who can tig weld to do the aluminum.
Old Dec 28, 2006 | 07:57 PM
morris's Avatar
morris
Anyone have any suggestions as to whether I shoud go with a booster pump or a second walbro?
Old Dec 28, 2006 | 09:36 PM
Supraownzu's Avatar
Supraownzu
guess that depends on total horsepower you plan to make. two walbros will definetly support a ton of power, but they are kinda a pain to get set up.
jwin
Mar 13, 2013 09:43 PM
xspsi6
Jun 21, 2012 01:41 PM
76mmturbo
Apr 9, 2008 07:34 PM
twizted
Dec 11, 2007 03:59 PM
