1uz v8 motor??
Old Nov 13, 2006 | 08:01 AM
cino78h's Avatar
cino78h
Default 1uz v8 motor??
Is all LEXUS v8 motor INTERNAL are the same?cause my GS400 i thinks its needs an total rebuilt and i got an 93 sc400 motor as an spare and could salvage parts from its.
oh and what is the hp spec between them two motors??i know the sc400 is like 250 0r 300 hp??
Old Nov 13, 2006 | 09:24 AM
morris's Avatar
morris
THat would be a negative ghost rider. The rods are different which I am pretty sure will requrie different bearings. Also the 98 has VVTI for valve timing and the 93 does not. Heads are different and the pistons are differnt at least the domes.
Old Nov 13, 2006 | 12:23 PM
JBrady's Avatar
JBrady
While remotely possible you would NOT want to do this. You would spend much more money and get much less back than simply locating a correct engine. Correct engines would be from 1998-2000 GS400s, LS400s and SC400s. You may have to swap the oil pan if you get an LS or SC engine but otherwise you are fine.
Another more expesive option would be a 2001+ 4.3 liter 3uzfe engine but that could uncover some incompatibilities with the VVTi or something else.
BTW the 1990-1994 1uzfe engines are rated 250hp but in actuality only make about 230hp. Your GS400 makes 300hp. No contest.
Old Nov 14, 2006 | 02:57 PM
cino78h's Avatar
cino78h
thanks dude!ok of course i have to swap all the harness and ecu??how many ecu does an GS400 HAS???i heard there are more than one??well i blew my gs400 and got an spare part sc400 sitting here in my yard so i'm gonna do this swap so i can get this puppy on the road again!
Old Nov 14, 2006 | 03:07 PM
morris's Avatar
morris
it aint that simple, the GS400ecu controls other things than just the engine. Like the tranny, like the AC like the dashboard etc, etc, If you do use the SC ecu it may not control all the other stuff.
Old Nov 14, 2006 | 03:24 PM
cino78h's Avatar
cino78h
thanks!so bacially i can used the block and head from the sc400 and just used the IM from the GS400 and ecu??
Old Nov 14, 2006 | 03:40 PM
morris's Avatar
morris
I dont know if the GS400 ecu is going to work with the SC400 block and heads.
THe heads are different on the SC it also does not have VVTI which the GS is expecting. The GS ECU is obd2 and I think the older SC is obd1, which may also create a problem.
What is IM?
Old Nov 14, 2006 | 05:35 PM
THE_CEO's Avatar
THE_CEO
What is IM?
i think its "internal mechanisms"...just a guess.
CEO
Old Nov 15, 2006 | 10:47 AM
Lextreme's Avatar
Lextreme
You can use everything in the SC400 shortblock (block, crank, mains and rods) except the pistons. Heads are different between the two generations.
Old Nov 15, 2006 | 11:00 AM
JBrady's Avatar
JBrady
Here is the thing. While EVENTUALLY possible to get the early 1uzfe to actually work... the end result will be both EXPENSIVE and reduce the value of your car.
Years ago I did a 5.0 HO swap into a 1987 TBird Turbo Coupe. I bought a wrecked Mustang GT with virtually everything I needed except a harness. Expected total project cost at $2000. $5000 later it was finally reliable. I tell you this because all the trouble you will face is not easily recognizable. Trust me and re-read the first paragraph above.
You should be able to find a 1998-2000 engine for around $3000. SELL the SC parts to offset some expense. You will end up with the RIGHT engine, the RIGHT power, no CRAZY tuning, repair and diagnostic problems, NO extra vehicle depreciation (NOBODY wants a GS400 with an old weak engine and problems). Believe me when I tell you the cost will most likely be LESS than the SC engine swap.
Do what you want but ignore my advice at your peril.
Old Nov 15, 2006 | 02:16 PM
Lextreme's Avatar
Lextreme
Why would you want a SC400 engine. It would be cheaper if you just rebuild your GS400 engine.
Old Nov 22, 2006 | 12:56 PM
cino78h's Avatar
cino78h
true that!i'm just gonna either pick up another GS400 engine or just swap in a 2jzgte aristo!
Brucelee28
Nov 13, 2016 04:04 PM
snakehead
Jan 10, 2013 12:56 AM
702SC400
Jun 11, 2009 11:24 AM
sliva001
Mar 15, 2007 05:01 PM
Luv Da Lex
Oct 6, 2004 07:16 PM
