Throttle PS/Cable? + BOV Questions
Old Oct 19, 2006 | 11:18 AM
Kharizma's Avatar
Kharizma
Default Throttle PS/Cable? + BOV Questions
alright, so my car will IDLE by itself now when it's warming up (when it's cold it idles around 500RPM... what does that mean? i just have to adjust my throttle body cable right? has nothing to do with fuel or anything, correct?
i'm plannin' on doing this:
re-adjust the throttle body cable
fix another oil leak i found
unhook the SAF-C II
reset my ECU
put in the PLX Wideband + EGT Kit
put in Blitz Turbo Timer + Boost Gauge
complete fluids service (flush + refill)
clean MAF sensor
that's all i can think of at the moment.. anyone else have suggestions?
also, does anyone know if i need a vacuum line hooked up to my BOV? 'cause it's constantly blowing off and people are tellin' me it's not supposed to do that, and when i drive, you can't hear it unless i floor it and then let go of the gas and even then it's quiet. suggestions?
Old Oct 19, 2006 | 03:29 PM
macd7919's Avatar
macd7919
Umm, yea, you need a vacuum line hooked up to your bov or else nothing is going to keep it closed under boost except for the spring. Did you have a shop install this setup? If they didnt hook up a vacuum line to your bov it doesnt sound like they have a clue.
Old Oct 19, 2006 | 04:23 PM
Kharizma's Avatar
Kharizma
what vacuum line hooks up to the BOV? and which hole so i put the vacuum line up to? there's 2 on the BOV and there isn't any spare ones that i haven't used up?!
Kharizma's Avatar
Kharizma
yes the shop installed the set up but the instructions dont' say anything about a vacuum line going to the BOV and we have no extra vacuum lines that could go to the BOV..
Old Oct 20, 2006 | 12:13 PM
HI98GS's Avatar
HI98GS
Just "T" off another vacuum line from an existing one.
Old Oct 20, 2006 | 01:47 PM
Dx3's Avatar
Dx3
What are you using a turbo timer for?
Jonny
Old Oct 21, 2006 | 12:43 AM
Kharizma's Avatar
Kharizma
HI98GS - does it matter which vacuum line i "T" off of?
jonny - since the vortech is centrifical (or whatever) they said it'd be best to have a turbo timer to cool it down.. so i said, hey can't hurt lol. does it hurt to have one or is it bad to?
Cp2295
Nov 26, 2016 12:24 AM
90Ls4004JG
Dec 27, 2013 07:09 PM
willfxp
Mar 7, 2011 12:59 AM
Suneet
12
Jun 7, 2007 11:33 PM
aliga
Aug 14, 2003 08:41 PM
