Stock LSD Gear Oil
Old Oct 9, 2006 | 03:13 PM
JDMToyota's Avatar
JDMToyota
Default Stock LSD Gear Oil
I am about to do my 30,000 mile tune up in two weeks time and was wondering if the stock LSD on the IS300 required any additive for the diff? I bought Valvoline Durablend (Synthetic Blend) 80W-90 Gear Oil today and wanted to know if that is all that is needed? Thanks.
Old Oct 9, 2006 | 07:27 PM
Tammy's Avatar
Tammy
Welcome !
If you check your owners manual to confirm,
The gear oil should exceed API GL-5 specifications and
Meet the service fill requirements for limited slip differentials.
Old Oct 12, 2006 | 07:03 AM
Lexmex's Avatar
Lexmex
You shouldn't need any additives with these synthetic differential fluids.
In addition, I believe your stock fluid might be an 85W90. My RX calls for an 85W90, but I have used a 75W90 Royal Purple MaxGear differential fluid (without any additives) in my RX300 without issue.
Thus, that 80W90 should be more than sufficient and no additives.
Old Nov 2, 2006 | 10:43 PM
wjbertrand's Avatar
wjbertrand
No special additives are needed for the OEM Torsen type rear ends as this design doesn't use clutch packs like some others. If you have fitted the after market TRD LSD, that unit uses the clutch pack design and would benefit from the friction modifier additives.
AFAIK, Lexus did not fit any IS300 from the factory with the TRD unit though.
waqas300
33
Mar 14, 2019 09:19 AM
Returd
Oct 16, 2017 06:14 PM
LEXSOOS
Performance
Oct 21, 2006 07:19 AM
alsilverbullet
Performance
May 21, 2005 06:10 AM
sun
RX - 1st Gen (1999-2003)
Jan 12, 2004 12:17 AM
