fuel rails / throttle body cable / idles
Old Feb 21, 2007 | 08:31 PM
  #31
JPI Racing's Avatar
JPI Racing
Originally Posted by blaise
Adjusting the throttle body cable will increase rpm's, Mine is set at around 650-700 at idle, with car in park. Of course I don't have the sc but either way It shouldn"t matter. If u remove the tps u most definately will get a cel light .........a no brainer. I personally would of ran the car without installing anything other than the sc, this would make diagnostics a lot easier.
Vehicle idle low due the extra load that it has drive the supercharger. Stock ECU doesn't know you have a supercharger installed. By adjusting the screw, the throttle plate open up for a little more. Therefore the vehicle idling a little higher. After a couple of weeks, the stock ECU will by itself and bring the idle speed down. Is there anyway to defeat this problem? Absolutely, Reset your ECU every start up. GS430 is a little harder to do and this ECU is totally from the GS400.
JP Importz
Old Feb 21, 2007 | 08:40 PM
  #32
JPI Racing's Avatar
JPI Racing
Originally Posted by Supraownzu
some of the obd2 scanners like the snap-on one will read TPS, so you could adjest it according to that. when i fired mine up with the AEM, we had to set what the TPS was at. you can also always find a stock car and measure the TPS voltage with a meter to find out what it should be. mine on the GS300 was something like .61 volts when totally shut.
as for the throttle cable adjusting the idle, never heard of that before. the IAC controls idle, the more it opens, the higher the idle. with a supercharger, i wouldnt think you would want to open the throttle blade at all to increase the idle.
Sir,
AEM is a stand alone unit and of course you have to recalibrate the TPS so the computer would know where is the WOT point. IAC is actually built in the motor and control by a magnetic field. When installing a new TPS, you will need a scanner to adjust your TPS to 13% and then lock it down. OBDI system is totally from OBDII( DBW).
JP Importz
Old Feb 21, 2007 | 08:48 PM
  #33
JPI Racing's Avatar
JPI Racing
Originally Posted by Kharizma
bump..
car still will NOT IDLE!
i don't know what's going on.. any help/suggestions please!?! lol
Find a tuner that knows how to tune your s/c or take the kit off!
JP Importz
Old Feb 21, 2007 | 10:18 PM
  #34
Supraownzu's Avatar
Supraownzu
Originally Posted by JPI
Sir,
JP Importz
sir, thank you. i'm pretty aware of all that, even when i wrote it 4months ago. also, a TPS is a linear scale sensor. if 0v is 100% closed, and 5v is 100% open, what is 13% of 5v??? .65v is the answer. i agree that the best way would be to set it with a scanner, in fact i suggested that as well earlier.
Old Feb 22, 2007 | 12:09 AM
  #35
Kharizma's Avatar
Kharizma
fly out here huh.. how much is that gonna run me lol.. i'm in colorado springs, not denver though.
we're gonna try a few things on saturday.. hopefully it works. who knows was just seeing if there were any new ideas or inputs that could be taken in. lol
Old Feb 22, 2007 | 12:11 AM
  #36
Kharizma's Avatar
Kharizma
oh and there aren't specific lexus tuners.. lol there's pimp *** dsm/honda tuners.. no such luck for me
and gill - i'm runnin' rc 330cc injectors
Old Feb 22, 2007 | 06:37 AM
  #37
Dx3's Avatar
Dx3
Remember when I told you how much a PITA having a supercharger was and that I regretted it??? This is why
Hope you get it taken care of man - good luck...
Jonny
Old Feb 22, 2007 | 06:48 AM
  #38
JPI Racing's Avatar
JPI Racing
I'm not questioning your answer. But when intalling a s/c kit, The TPS need to be left alone. If someone try to adjust the TPS to raise the Idle speed. Then they haven't done their homework or not really know how system works.
JP Importz
Old Feb 22, 2007 | 06:54 AM
  #39
JPI Racing's Avatar
JPI Racing
My schedule is pretty tight right now. So I can't go anywhere for another month. You will need some kind of fuel controller to your fuel and 330cc injectors is a little too much for 5 lbs of boost. If you are running too rich, your Long Term Fuel trim are out of quack. Closed loop tuning is very important. Good luck.
JP Importz
Old Feb 22, 2007 | 10:41 AM
  #40
GILLEXUS's Avatar
GILLEXUS
Do you have the the person that sold you the kit did include the 310's or did you only get the 330's w/ it?
It shouldn't take 4 months to install and tune a s/c kit. Any lexus tuners in the area? If not I can fly out and fix all the bugs out for you . Are you in the Denver area?
JPI
Now that is what I call service
Old Feb 22, 2007 | 11:04 AM
  #41
GILLEXUS's Avatar
GILLEXUS
Kharizma,
Have you vistited Texas Yet? If the car will run well enough on the highway, Drive to JPI's shop and let him work his magic. I've checked and I think he's about 700 miles from Denver. This might seem exreme but having someone who knows what they are doing can get it done right. The more you put in it experimenting it will cost you more time and $$ and in 6 more months you'll still be unhappy.
Jason has already done at least one RMM kit that I know of. I think his name was Randy and he used the S-AFC like you and he was happy.
There aren't any shops up here in Denver area that I know of that will take your car from where it is now ( idle, running rich,dampers adjustment, and TPS) and get it right. You need someone that knows Lexus motors and tuning them. the Lexus dealers and Lexus specialty shops I don't think will much from the factory stuff.
I've thought about making a vaction trip to his shop.
Just my $.02
Old Feb 22, 2007 | 11:12 AM
  #42
Dx3's Avatar
Dx3
Gil,
Stop off in Tulsa for a beer on yoru way through
Jonny
Old Feb 25, 2007 | 03:27 AM
  #43
Kharizma's Avatar
Kharizma
ok.. we disconnected the supercharger belt and the car idled/ran fine.. so the supercharger is makin' the car not idle properly.. ideas?
Old Feb 25, 2007 | 09:24 AM
  #44
JPI Racing's Avatar
JPI Racing
The supercharer isn't your problem. It's the tuning and setting up. I answered all the questions that pertain to your problem. My last advise, find someone that is familiar with your set up.
JPI
Old Feb 25, 2007 | 07:43 PM
  #45
LEXSOOS's Avatar
LEXSOOS
Dude, Take JPI advise and let him work on your car a.s.a.p
