What to do ??? Engines blown
So, please fill in the blanks for us.
Do you know WHY your engine blew yet?
You say you know someone that can reprogram the ECU for the engine and possibly the transmission... contact info on this source please?
Is your 225hp nitrous system a port system or single point system?
Did your first engine blow and if so do you know why?
Pictures and details on the engines please?
Until you KNOW why your engine failed you cannot place the blame. I am always concerned about engine builds as it is NOT easy to get everything really right. IMHO if you were not running a fogger at each PORT and since 225 does not divide by 8, I would say that distribution problems likely caused this failure. Checking the oxygen sensor or even wideband does NOT indicate cylinder to cylinder rich/lean conditions only bank to bank.
Please provide as much detail as you can because many on this forum are very interested in making more power and many could really help you if needed.
Also the idea of running that much nitrous without any kind of fuel management is very confusing to me. Can you tell me what you are doing to make that work? How does the ECU keep up with it, what are you doing to add more fuel? Is more fuel needed? what size injectors are you using with the setup.
I second alot of that. What is blown? Depending on what it is I would be willing to buy the blown motor from you. Shoot me a PM with a price if you want to sell it. I am very interested to hear what broke and ideas on why.
Good luck
