Blitz Drop in Filters for 2006 IS250/IS350
Old Jun 23, 2006 | 01:04 PM
  #31
pocky's Avatar
pocky
mooncake master
Originally Posted by caymandive
Did you reset the ECU prior to installing the air filter? May or may not make a difference with the slight increase in airflow. Also, why would the intake tube have to bend to install the filter? All you do is pop the side black engine cover, pop open the air filter lid and drop in the new filter.
Did not reset the ECU.
Well, for the OEM pipe, you can just open the cover with the pipe on it cause it can bend upwards. Keep in mind, the 2IS's filter cover is attached to the pipe of the intake now. Whereas, the 1IS it's a half cover and it comes right off. Not as simple as the 1IS. You'll see what I mean when you try to pull it open.
fastsmurf0
Performance
Jan 26, 2009 09:18 PM
sixth
Performance
Jul 26, 2006 07:52 PM
4TehNguyen
Jul 12, 2006 08:36 AM
