Supercharger People - Please read
Old May 14, 2006 | 09:32 PM
Dx3's Avatar
Dx3
Default Supercharger People - Please read
Guys,
You think I could get away with a 2.62 pulley?? I was going to go with a 2.87 but the company doesn't have them in stock and it is going to be several weeks before they can get one in. They said they can ship me out a 2.62 tomorrow.
I was thinking with a Gatorback it may not slip. What do you think? Come on Turbopooh
Jonny
Old May 14, 2006 | 09:40 PM
trbopooh's Avatar
trbopooh
two words: belt slippage.
Old May 14, 2006 | 09:43 PM
Dx3's Avatar
Dx3
I knew that was coming!! I have a 3.12 but I want a little more boost than that. I guess I need to find somewhere else that has a 2.87
ANy ideas?
Jonny
Old May 14, 2006 | 09:46 PM
trbopooh's Avatar
trbopooh
now now. don't get greedy. wouldn't you rather have a consistent boost with no slippage? k bye
Old May 14, 2006 | 09:48 PM
Dx3's Avatar
Dx3
So you think I should go with a 3.12?
Jonny
Old May 14, 2006 | 09:52 PM
trbopooh's Avatar
trbopooh
that up to you. i did find a vendor on ebay.
http://cgi.ebay.com/ebaymotors/Power...65511273QQrdZ1
btw, did you every try superchargersonline.com or any other vortech vendor?
Old May 14, 2006 | 09:54 PM
trbopooh's Avatar
trbopooh
http://superchargersonline.com/produ...lley&offset=40
Old May 14, 2006 | 09:55 PM
Dx3's Avatar
Dx3
That guy is $20+ more expensive than the other people on there. But then again the auction I won with the other guy - he contacted me 3 days later after I had paid him to tell me there was a misprint on the auction and they ony had an 8-rib. They were cool about it and offered a refund or $10 off a different pulley.
I guess I will just get a refund and go elsewhere.
So do you think 2.87 or 3.12 or what?
Jonny
Old May 14, 2006 | 09:56 PM
trbopooh's Avatar
trbopooh
you should have no problems with fuel with your 440's for 2.87, but what about slippage?
Old May 14, 2006 | 09:58 PM
Dx3's Avatar
Dx3
Gatorback baby!! It seems to help a lot
Jonny
trbopooh's Avatar
trbopooh
or how about a compromise and get the 3.00???
Old May 15, 2006 | 05:08 AM
Dr.G's Avatar
Dr.G
Jonny- I've been running the 2.62" pulley with a Gatorback belt for awhile now and have been doing just fine Albeit, when I dropped down from the 2.87" pulley I was running out of my 310cc injectors up top so my shop had to tune me down until I go up in injector size. That issue will be solved in the next couple of weeks hopefully once I get a chance to swap out with Morris and his 370cc's inj. As for belt slippage, my thoughts are, it's going to occur regardless as the belt wears/loosens from all the aggressive driving- this will occur regardless of what pulley size you run. A friend here in ATL has a high power SC'd IS300 and he even runs into the same issue, just not as so soon And just so that you know, I've ran them all from the 3.33" all the way down to the 2.62". Now what has seemed to help prolong the inevitable slipping issue was my shop fabricated an additional aluminum support bracket that braces the SC to the engine to prevent SC from flexing forward under full throttle, we noticed that happening while dynoing. If I get and chance and can remember I'll try take some pics and post them here or forward them to you if you'd like. Hope this helps, if you can readily get the 2.62" just go with it, if you're ordering from Vortech as I did, just make sure you have them send to RMM to machine it down to spec. for our application.
Old May 15, 2006 | 08:01 AM
Dx3's Avatar
Dx3
Thanks for the input man SO what does RMM charge for this and what all is involved??
Would greatly appreciate pictures of this bracket
Thanks again man.,
Jonny
Old May 15, 2006 | 08:23 AM
Dr.G's Avatar
Dr.G
I can't remember exactly what they charged it's been so long. I think if you order the pulleys from RMM, in which they acquire the pulley from Vortech and then machine it down to size and ship out to you, it was like $100-130?? Or you can order the pulley yourself ~$72 from Vortech, have them ship to RMM and then RMM charges like $25-$35 to machine it to spec and then ship to you. I would suggest the latter b/c my experience with RMM in the past is that they tend to be "forgetful" and then make excuses for delays.
The pulley's straight from Vortech are a few mm's to wide and cannot be directly mounted to our setup or you will certainly get belt slippage if not the belt jumping off track (learned this firsthand with the 2.87" pulley) So RMM knows the exact specs of the width the pulley needs to be to fit their design. Make sense
Thanks again man.,
Jonny
Old May 15, 2006 | 09:01 AM
Dx3's Avatar
Dx3
Sounds good man. I will get it sent out there and have them do it. Appreciate the responses.
Jonny
