Finally Installed (Insert Guess Here)
Old Apr 20, 2006 | 07:01 PM
  #31
GILLEXUS's Avatar
GILLEXUS
Originally Posted by RMMGS4
The factory O2 sensors are already in that location. All I did was add a second threaded bung for my independent O2 sensor when I hook up my wideband down the road.
Also the sensors are both pointed downwards so as far as heat radiation, the sensors are facing away from most of it.
The rule of thumb of 24" sounds reasonable, but since the factory set up doesn't follow this I assume it's OK.
Thanks for the note of concern though.
Glenn thanks for the idea to add this. I'm going to get me a bung and plug tomorrow so I can have this done before my header install next week. I'm sure want to add a wide band guage. This is a great time to add it since it is not recomended to put the wide band 02 sensor after the cats.
actualy don't both sensors point more upward?
Old Apr 20, 2006 | 08:03 PM
  #32
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
In the installed position the stock O2 is pointing at the 7 o'clock position and the other bung is in the 4 o'clock position.
Yup if you want the sensor before the cats, this is where it's got to go.
Make sure you position it where you see it on my header. You might get close to hitting the steering linkage if the bung is inserted at the wrong angle.
Next time my car is on a rack I'll have to take a pic of the exact location and the clearance.
You could also consider installing it on the passenger side header. I never thought to look on that side.
Old Apr 22, 2006 | 03:56 AM
  #33
GILLEXUS's Avatar
GILLEXUS
Glenn from the looks of your header, it does look like it is the pass. header. Looks like there is just enought room to fit your hand down the passeger side and touch the header flang. On the drivers side it is impossible.
From looking from the top of the engine and fealing w/ my hand, seems like there is room to mount the sensor at 9 o'clock, (stock sensor at 7 o'clock) 4'o'clock and 3'oclock w/o hitting any thing.
If the sensor is not to long, maybe it can be mounted at the 9o'clock position on the pass side and it be installed or removed with from the engine bay??
Here is a pic of Pearlpower's header on his SC430 from the passeger side.
https://www.clublexus.com/forums/sho...7&postcount=40
Old Apr 25, 2006 | 12:23 PM
  #34
redgs4's Avatar
redgs4
Originally Posted by redgs4
Nice pics Glen. I like the black jet hot coating. But in the end I don't think it matters. Whether looking from the engine bay downward or even from below with the car on a lift, I could not see any part of the headers except where they bolt to the cats.
I take it back - I did such a good job of "aging" the headers that I did not realize I was staring straight at them. They can easily be seen from the drivers side.
Old Apr 25, 2006 | 12:46 PM
  #35
RMMGS4's Avatar
RMMGS4
The sensor is rather long, plus I have a feelingthat the sensor tip needs to point down, so atleast an 8 o'clock position might be a better choice.
Now referencing these positions, you are referencing base off of the installed position. The headers when installed are about at a 45 degree angle at the header flange, so our positions will be off if not factoring this is.
Pearlpower installed headers in an SC so I can't say if a GS will be the same. I thought SC430's have more room than a GS?
nicklausw
IS F (2008-2014)
Jan 12, 2017 01:40 PM
ljdsong
IS F (2008-2014)
Nov 29, 2016 07:36 AM
yemgi
IS F (2008-2014)
64
Jul 20, 2015 03:16 PM
FIGS
IS F (2008-2014)
31
Sep 19, 2013 07:53 AM
sgv_bum
RX - 1st Gen (1999-2003)
Apr 14, 2009 10:33 PM
