can i raise the compression ratio in my 2JZ?
Old Apr 6, 2006 | 01:46 PM
sockfocks's Avatar
sockfocks
Default can i raise the compression ratio in my 2JZ?
How much compression ratio will the 2JZ handle before having detonation problems using 91 octane? I want more power but FI isn't feasible at this moment. I figured changing too a thinner gasket would be beneficial to power.
Old Apr 6, 2006 | 05:22 PM
Abear's Avatar
Abear
CL Folding 200,000
No matter how much you try, the most your gonna squeeze out of the 2JZGE without going to FI is about 20-50 horsepower. 20 being I/H/E, which is still on the cheap side. 50 being I/H/E, cams, bigger injectors, bigger MAF(or you can eliminate the MAF and go standalone, but why without FI), cams. Everything is gonna cost alot. I dont personally know how much you can get out of the 2JZ, but from what I read on Supra-Forums, its pretty hard to get power. You can try a thinner headgasket, but I wouldnt push the ratio higher than 12:1.
Old Apr 10, 2006 | 07:38 AM
sockfocks's Avatar
sockfocks
anyone else with information?
chillchewy
Sep 13, 2014 03:21 PM
rcchris7
Nov 27, 2012 02:59 PM
bgsymalone
Performance
32
Jan 13, 2010 07:46 PM
mtparker18
Performance
May 15, 2009 09:25 PM
silent1pro
Dec 14, 2006 08:23 PM
