SC / FI Questions
Did anyone make a SC setup specifically for the GS430, or are they just a modification from the GS400 setups?
Whats involved with replacing the injectors, soldering? How come?
What other kits are available besides RMM? Who can I buy them from?
Last question. I am most likely going to go with a TTE lip, instead of a full bumper. Will an intercooler fit behind this semi-stock setup or will I need to go with a replacement bumper? If I need a replacement what will work?
Thanks in advance.
Thanks in advance.
You do not have to replace the injectors unless you plan on running more than about 8lbs of boost - and with the kit I strongly doubt that is what they offer.
I don't know about the TTE lip - I had to cut a little off my L-Sportline bumper but it was the actual IC piping and not the actual intercooler.
Have you read Morris' thread titled "So you think you want FI"?? I would suggest it before you go FI.
Jonny
