Royal Purple 9 horses?
Anyone running Royal Purple in the diff besides me? Any before and after dyno numbers? I came across these videos showing 9 horsepower increases using Royal Purple
http://www.royalpurple.com/video/video.html
Originally Posted by LEXISM
i have heard that this oil ups your HP's....
Originally Posted by Dx3
Do they sell this at Autozone and places like that or do you have to order it from somewhere??
Jonny
Jonny
http://www.jegs.com/webapp/wcs/store...tegoryId=14851
this may not be quite what you were looking for, but, I did use that oil in my ZX-12R which I happen to drag race a lot. I think it's good oil.
As far as getting 9 hp though, well, it's hard to say, but certainly you'd get more than when using thick old standard 90w or whatever is in our differentials.
I wouldn't expect it to be any more than any other synthetic though.
(haven't seen any tests against Amsoil, Mobil, Redline, etc)
You're right Shocker, that would make it *easier* for the average guy to buy and install.
personally, I don't mind buying a separate additive if it means that my base oil that I'm putting in the differential is better. (I have my LSD here in the garage, to be installed after drag testing the headers I recently put on)
Anyone know if using an additive on the supra unit will have any adverse effects
this post is kinda wierd - i was thinking about posting something lastnight on the same subject but not the Royal Purple product something else- i saw it on sports car revolution lastnight on the speed channel- the did a dyno before and after and it was a 9 hp gain- from cutting down on friction they said- ?- im afraid to use stuff like that- ""ect. sea foam""" but im not sure if a reputable tv show says it works it must right?????????????
Originally Posted by rheiy
From what I understand, the supra tt lsd does not require additives where as the TRD unit does.
There are plenty of aftermarket differential fluids that have the friction modifier built in (I use Redline which does), not only Royal Purple does.
On the 9hp claim, I'd guess that changing the oils with any decent synthetic is going to improve performance somewhat. I'd like to have seen them do it with fresh synthetic fluids (some other brand) as the 'before'.
