View Poll Results: Do you hit your limiter
No, never
33.33%
No, even though I have 3.76 and 2800 TC
13.33%
Yes, but I don't have 3.76 or 2800 TC
13.33%
Yes, I have 3.76 but not 2800 TC
0%
Yes, I have 2800 TC but not 3.76
13.33%
Yes, and I have both
13.33%
Seldom, I have 2600 TC and OEM gears / TRD LSD
13.33%
Voters: 15. You may not vote on this poll
Forced Induction Poll
Old Nov 30, 2005 | 06:20 PM
Dx3's Avatar
Dx3
Default Forced Induction Poll
Guys,
Trying to work out the exact culprit of who is having limiter problems and who isn't. Right now I am wanting to get input from all people with FI. Please respond.
Thx,
Jonny
Old Nov 30, 2005 | 06:26 PM
TLW's Avatar
TLW
johnny , have you ever read this ?
Edit :never mind
Old Dec 1, 2005 | 09:01 AM
morris's Avatar
morris
What about 3.23 gears and 2600 stall TC?
Old Dec 1, 2005 | 10:45 AM
Dx3's Avatar
Dx3
LOL - I'd be here all day with poll choices!!!
Jonny
Old Dec 1, 2005 | 03:12 PM
3dog's Avatar
3dog
Smile rev limiter
I've got the SC the 3.76 and the 2800.
It all depends.
If I leave it in second or third gear I will eventually hit the rev limiter.
If I leave in in 5 or drive I might hit the limiter but the gears change so fast to the next gear that it is not noticeable at least to me.
I did not do the pollbecause I could not figure out what to check
I think you need to be looking to getting the tranny to change gears faster
Ivan
3dog
Old Dec 1, 2005 | 03:50 PM
sockfocks's Avatar
sockfocks
Basically he is looking for a combination of gearing or stall speed that allows the transmission to shift without hitting the rev limiter. Higher gearing allows the engine to wind up faster which may be causing the rev limiter problem. Another issue is stall speed. Higher stall speed means the transmission "slips" unti the engine reaches a higher rpm, so your effective RPM range is smaller. I believe a lower stall speed may help. Usually high stall speeds are associated with drag strip cars, so they can powerbrake and keep the engine in the powerband.
Old Dec 1, 2005 | 03:59 PM
TTurboPimp's Avatar
TTurboPimp
Bro, quit chasing ghosts and buy the electronic controller......$800, and problem solved. By the time you start changing gearing, etc., you would spend that much if not more anyhow.
Old Dec 1, 2005 | 08:33 PM
jp430's Avatar
jp430
I hit the rev limiter very rarely. I would have to agree that upgrading the tranny (valvebody) would solve this problem. I have both TC and 3.76 LSD.
Old Dec 2, 2005 | 05:50 AM
Dx3's Avatar
Dx3
I have an upgraded valvebody already.
jonny
Old Dec 2, 2005 | 06:52 AM
Mr Johnson's Avatar
Mr Johnson
Which controller is this again?
Old Dec 2, 2005 | 07:22 AM
morris's Avatar
morris
Sleeper Yee right
http://www.powertraincontrolsolution...content-4.html
Old Dec 2, 2005 | 03:59 PM
Dx3's Avatar
Dx3
Anyone think of checking if they still hit their limiter with ECT off??
Jonny
Old Dec 2, 2005 | 07:45 PM
jp430's Avatar
jp430
jonny
I guess I thought wrong then. Good thing you did it for me. I think I am going to look at that trans controler, while I am having my new motor built.
Old Dec 2, 2005 | 08:51 PM
TTurboPimp's Avatar
TTurboPimp
You can and will hit the rev limiter...even with the valve body. The only way to correct the issue is to run a standalone tranny ecu. By the way, hitting the rev limiter in a couple of gears means that you will be shifting at WOT roughly 5 to 7 hundred rpm's earlier to combat the issue......basically shifting early to let the factory ecu catch up and slide the tranny into the next gear. Think about how much money we spend to FI the GS, then think about how much power and time you are losing by shifting early....and guessing when to shift. One word for you....again....ECU!!
Old Dec 3, 2005 | 04:55 AM
morris's Avatar
morris
do you have one and if so how does it work? How diffucult is it to setup etc.
