oil drain plug crush washer?
Old Nov 1, 2005 | 10:06 AM
Benjamin T's Avatar
Benjamin T
Default oil drain plug crush washer?
i'm a noob so please don't flame
this is for a 99 gs400... i just went out and bought a napa gold (wix) oil filter and there is no crush washer for the drain plug... is the existing washer reusable?
Old Nov 1, 2005 | 10:12 AM
bmgs400's Avatar
bmgs400
I would recommend going to Lexus or Toyota dealer and buy an new washer for a few pennies.
Old Nov 1, 2005 | 10:29 AM
bob2200's Avatar
bob2200
I think it's closer to $1 in cost. I won't say you can't use the old one again; IMO it partly depends on how safe and secure you want to feel, how often you plan to check the oil level, etc.
Old Nov 1, 2005 | 12:01 PM
meZoom!'s Avatar
meZoom!
Super Moderator
The GS you have does not use a so called "crush" washer for the engine oil drain. The existing washer should be a black paperish washer, sold at Toyota (most any modern Toyota has the same one) or Lexus. When you take out the drain plug, many times, the washer is stuck to the outside of the oil pan. At this point, you can either: scrape it off of the drain pan with a flathead screwdriver and use a new one OR inspect the washer stuck to the oil pan, check that the surface is flat, and reuse it as is (don't remove). If it leaks, you can change it next oil change (it wont leak bad if you tighten the plug sufficiently). If the vehicle was previously serviced somewhere else, they might have used other types of washers.
Old Nov 1, 2005 | 12:26 PM
Benjamin T's Avatar
Benjamin T
it was serviced somewhere else.... there is a metal crush washer.
thanks for that info.... btw, why paper? i'm so used to metal washers... unless i'm missing something?
Old Nov 1, 2005 | 12:32 PM
meZoom!'s Avatar
meZoom!
Super Moderator
As long as it does the job right, there's no problem. Paper is probably more economical....just my guess. I guess when you tighten the plug over the washer, it "crushes" a bit. It's more like a gasket though. Honda, Nissan, Subaru....all those cars still use metal washers for the most part. I HAVE seen Toyotas with metal washers on the drain bolt though.
Old Nov 1, 2005 | 01:18 PM
JellyBean's Avatar
JellyBean
Go ahead and reuse it. You'll be fine. Years ago I reused my Civic's aluminum crush(ed) washer for years before I finally bought a bunch. I use them now in the Lex and they work fine. At least you don't have to scrape them off. JB.
Old Nov 3, 2005 | 09:45 PM
joshoowa's Avatar
joshoowa
<= $1 shoot its like 3 bucks at my local toyota dealer...
GRPFAN
RX - 3rd Gen (2010-2015)
Mar 26, 2012 09:14 AM
bozilla
Jan 31, 2011 12:04 PM
Chiadon
May 1, 2007 01:32 AM
ice7
Maintenance
Feb 2, 2005 02:00 PM
toy4two
RX - 1st Gen (1999-2003)
20
Nov 26, 2003 03:20 PM
