Need engine light help - PLEASE
Old Jul 11, 2005 | 05:59 AM
GSTALEX's Avatar
GSTALEX
Default Need engine light help - PLEASE
Hey everybody, this weekend i installed a weapon r secret weapon intake in my GS 300 and the engine light turned on. I even disconnected the battery for an hour. All the hoses and clamps are tight and it's still on.
What do i do now?
thanks
rafael
Old Jul 11, 2005 | 08:59 AM
Dx3's Avatar
Dx3
Pull out the ECU -1B fuse for an hour.
Then go to autozone or somewhere and clear the codes.
Jonny
Old Jul 11, 2005 | 09:53 AM
GSTALEX's Avatar
GSTALEX
where do i find that specific fuse and also i heard autozone is hesitant on clearing codes for you.
thanks for getting back
rafael
Old Jul 11, 2005 | 10:00 AM
Dx3's Avatar
Dx3
It is in the fuse box under the hood. Look on the back of the cover and it will lead you to the fuse. I believe it is at the bottom on the left side.
Yes they are. Ask them if you can borrow their scanner and have someone go outside with you. You can clear the code and give it back to them. This is what I did when I installed my SRT Intake.
Good luck,
Jonny
Old Aug 5, 2005 | 07:40 AM
chicagoblknazn's Avatar
chicagoblknazn
Doesn't just disconnectting the battery clear the codes?
Old Aug 5, 2005 | 10:50 AM
Benjamin T's Avatar
Benjamin T
i'm a little confused as well... am i to understand that disconnecting the battery clears the CEL light, but what will happen if the codes stay in the ecu?
Old Aug 5, 2005 | 03:26 PM
RONSKI23's Avatar
RONSKI23
The codes do stay in the ECU - go to autozone and get the scanner to clear the codes - but if it's a hard code - it'll come back - thats what happened to me - i even put back inthe stock intake and i still have a code - p0161.
have to tak it to get checked out -
Johnny - thanks for the autozone advice.
ron
Old Aug 5, 2005 | 03:42 PM
Dx3's Avatar
Dx3
ron
U r welcome man.
Jonny
Old Aug 6, 2005 | 08:59 PM
JPI Racing's Avatar
JPI Racing
What is the code? I'm sure it's the P0171, Lean conditon. Have someone check your long and short fuel trim. Hook up the vaccum and tell us that numbers you are getting at idle? Find out the problem and fix it. Don't just disconnect the battery and hope for the best.
JP Importz
Old Aug 7, 2005 | 06:00 AM
Benjamin T's Avatar
Benjamin T
JP Importz
long and short and fuel trim? what is that? this is the exact code (cyl. bank 1) i'm getting for the hks intake setup in our 99 gs400 (it came with the car). everyone blamed the intake and the dealer threatened to charge straight time to diagnose. all i've done so far is disconnect the battery and re/re the entire intake setup right to the throttle body. so far... no cel.
one thing that i've noticed though... the cel always seems to come on when it's hottest outside (we're pushing past 30'c some days). but when it's cooler or at night, it never comes on... why is that?
SABIR
Jul 21, 2016 12:34 AM
HollyM
IS - 1st Gen (2001-2005)
Apr 5, 2015 05:39 PM
smokedawgs
RX - 1st Gen (1999-2003)
Apr 25, 2008 10:05 AM
NYlexus
Feb 14, 2007 07:12 PM
BriMcc
Jun 17, 2003 01:02 AM
