Help!!!! 3 of 8 spark plug boots stuck!!!!
Old Feb 7, 2005 | 03:16 PM
ebruce2's Avatar
ebruce2
Exclamation Help!!!! 3 of 8 spark plug boots stuck!!!!
Guys, someone help me out here. I was changing my plugs to Torquemaster plugs the other night . Everything was going great until I got to the passenger side plugs. Three of the four coil packs on that side came loose from the rubber boots when I pulled them. I tried needle nose pliers on them for hours and hours and even ripped one of the boots a little. Tried to turn and pull steadily, even push-pull turn......NOTHING!
So I'm currently running 5 Torquemaster and 3 Denso Iridiums. I talked to my Lexus service writer and he told me to look for a pair of spark plug boot pliers. Problem is that I'm not sure which type of pliers is best for the soft rubber boot our plugs have.
Any suggestions would be greatly appreciated.!!!!!
Thanks,
Eric
Old Feb 7, 2005 | 04:15 PM
tmasta's Avatar
tmasta
had the same problem with my plugs also. i went to advanced auto (local auto parts store) and they had some ones (boot plug pliers) shaped sort of like a L for $5 and they worked like a charm. good luck!
Old Feb 7, 2005 | 04:28 PM
lex400pshR's Avatar
lex400pshR
Well U got lucky then...
I was almost done... 6/8 spark plugs installed (Denso Iridiums) last two the boots broke...
Well... I had to buy the whole unit(2) including Coil packs.. Lexus doesn't part it out.. U have to buy a whole unit.......
I payed so much man.. I learned a lesson.. don't let sparks go bad before changing... The heat makes the rubber sometimes melt.. in my Case
Good luck... And I hope U can avoid this
Old Feb 8, 2005 | 02:50 AM
RRocket's Avatar
RRocket
To prevent this from happening in the future, be sure to put some dielectric grease on the boots...
Old Feb 9, 2005 | 09:22 AM
ebruce2's Avatar
ebruce2
Oh crap!
The worst part is my car only has 52K on the clock. I might just end up taking it to Lexus and letting them change the remaining three. This way if THEY tear the last two they should cover the cost???
Thanks for the replies, guys.
Old Feb 9, 2005 | 11:51 AM
lex400pshR's Avatar
lex400pshR
Perhaps...
I went to lexus before installing it at a different shop.. and lexus told me $350CAD if I give them my own sparks...if Not I had to buy it from them(8)
I said to hell with that... I paid $100 to install 6/8 and $100 more after my car was sitting in his shop for 3 more days until lexus orders me the Coil packs etc...
So all in all over $600 cost...lol... that was pure suspension or LSD money...lol..
but its gotta get done sooner or later...
I say talk to lexus and see how much they want..
Meghanw1
Jun 23, 2016 04:40 AM
James4394
IS - 1st Gen (2001-2005)
Feb 23, 2014 05:19 PM
SeanIS350
Jun 24, 2012 10:50 PM
thaeleelyr
RX - 1st Gen (1999-2003)
Dec 22, 2010 05:44 PM
94SC4
May 24, 2008 09:17 PM
