Squeal At Cold Start
Old Jun 26, 2007 | 06:44 PM
  #31
engin_ear's Avatar
engin_ear
Everything in Moderation
Originally Posted by GSteg
WD40 is a temporary solution.
Getting a new belt is the fix
You guys are showing your youth. You don't need a new belt unless it's totally worn out. It usually just needs a tightening adjustment after stretching or shrinking a bit. And the last thing you want on a belt is WD-40. Think about what a belt needs to do - it needs to maintain tight contact with the pulleys, and not slip at all. Putting WD-40 on it can cause it to slip, and you can't see that, it will just be a fraction of a rotation, every rotation. This will translate into a percentage loss of power, or alternator voltage, or whatever the belt is connected to.
There are BELT GRIP/DRESSING compounds for use for this. Go to PepBoys or your local auto store. They either come in a spray or a squeeze tube. Permatex used to make a good one. Squeek will be gone, and traction/grip will be enhanced.
Old Jun 26, 2007 | 06:56 PM
  #32
engin_ear's Avatar
engin_ear
http://www.permatex.com/products/aut...ditioner_b.htm
http://www.valvoline.com/pages/produ...asp?product=32
Old Jun 26, 2007 | 07:33 PM
  #33
GSteg's Avatar
GSteg
Well it depends. Our GS has the pre-tensioner that's suppose to apply tension, even with an old belt. If your belt is slipping because the belt is stretched, the pre-tensioner is suppose to already accomodate it. Unless there is a way to manually adjust the tension, we can't tighten or loosen, unless I dont know about it?
Even on a conventional system, a stretched belt often points to small cracks. Tightening the pulley would stretch the belt out some more, and eventually lead to snapping it.
Plus it helps to have the Goodyear gatorback belt.
Old Jun 27, 2007 | 07:34 PM
  #34
engin_ear's Avatar
engin_ear
I guess you're right about the pre-tensioner, forgot about that.
What's the gatorback belt? Fiberglass reinforced or something?
Old Jan 23, 2008 | 07:31 AM
  #35
handzilla's Avatar
handzilla
I'm think I'm gonna look into getting a Gatorback belt to solve this problem. But what's the name of the noisy belt that is being replaced?
Old Jan 23, 2008 | 12:52 PM
  #36
DASHOCKER's Avatar
DASHOCKER
Damn this is an old thread.. LOL at me typing in caps back then. I was a nervous wreck lol
Oh, It is called the serpentine belt buddy. It is the only visible belt under the hood. If the squealing noise persists, the could be a result of a bad idler pulley.
cardboy008
GX - 1st Gen (2003-2009)
Jan 18, 2017 09:32 AM
jcat_350
Jan 25, 2013 11:02 AM
DASHOCKER
Performance
18
Jul 8, 2009 05:42 AM
HarrierAWD
RX - 1st Gen (1999-2003)
15
Jul 14, 2006 03:32 PM
DASHOCKER
Jan 3, 2006 09:06 AM
