Question for Optima battery owners...
Old Jan 21, 2005 | 11:19 AM
FutureGS400's Avatar
FutureGS400
Default Question for Optima battery owners...
The Optima website shows no application for a GS400...I've searched here on the forum for a model number with no success.
What model # or group size yellow top Optima did you use and were there any "fitment" problems? Thanks
Old Jan 21, 2005 | 03:07 PM
Neo's Avatar
Neo
The One
You'll need the D34 or D34/78 (if you want the side terminals). Size-wise, they are both the same. They are smaller than the OEM ones so you'll need to raise it. The OEM cables won't fit just right either, particularly the positive since there is a plastic piece that forces a 90 degrees bend to the connector. All the fitment can be overcome though.
Old Jan 21, 2005 | 07:53 PM
Indio's Avatar
Indio
Correct, your Optima dealer should have the adaptor which snaps on the bottom of the battery, if you are not the diy type go to Sears or someplace that will install it for you.
Old Jan 22, 2005 | 11:51 AM
FutureGS400
Thanks for the info guys!
So there is a plastic adapter or something to make this battery fit properly? I'll have to look into this further to see what my options are. My battery is the original and is 4 1/2 years old now so I want to change/upgrade before it fails on me.
Old Jan 22, 2005 | 01:24 PM
lex400pshR's Avatar
lex400pshR
I've gone through 3-4 units of yellow optima because of my system...
I never saw no plastic holder or whatever... Just took my old one out and put the new heavier unit in... Bada bing..
Old Jan 26, 2005 | 08:01 PM
LEXUS_KID's Avatar
LEXUS_KID
Thumbs down
Very Interesting I have nothing but problems with those batterys every color to from red, yellow and the blue they all seem not to last as long as they should.
Old Jan 26, 2005 | 08:28 PM
salimshah's Avatar
salimshah
25 Year Member
There are number of facors regarding a battery
Electrical:
Voltage 12v [formed by 6 series connected cells which produce 2v each]
Amperage ... usually listed as CCA (cold cranking amps) [larger number is preferred] {depends upon how many plates per cell are connected in parallel to increase current capacity}
Physical:
height , width and depth
Type of terminals and size of termials
location of terminals
Sealed or not
Back to Optima ... electrically they have no problem
Physicall size is a problem
Optimas are shorter in height and need a pedestal to raise it up. Lately they are sold with the plastic pedestal but even then it is roughly 1/4" short once placed on top. Hold down does not hold the battery without adding washers. But can be done,
Fortunatley the width and depth are same or slightly shorter so it can fit in the space.
The last problem is a bit difficult to over come. Make sure you get the battery with the post terminals. [it can have both the side and the top post in which case you will not be connecting anything to the side terminals]. The problem is that the posts are located further in from the corner of the oem battery. The solution is to replace the cables or force fit the cables and changing the 90degree angle. This causes tension on the post. [ It has worked for me for 2 yrs now without braking off the post]
Net: One can jury rig the optimas for GS but they are not drop in and that is why not listed as such by the manufacturer.
Salim
Old Jan 26, 2005 | 08:33 PM
FutureGS400
Default Thanks!
Appreciate the detailed response. Since I really have no need of a deep cycle battery (i.e. yellow top) I think I'll just look for a Sears Diehard Gold or something similiar that fits just right. I've had good luck with those over the years...
Old Jan 28, 2005 | 02:44 PM
TLW's Avatar
TLW
i bought a yellow top from Pep boys
and when i nstalled i found it wasnt as tall? as the lexus battery
so i traces the bottom
found a piece of wood to use a spacer painted it black
and good to go
i know when i searched i read someone else had to do this
it works car starts and im happy
Old Feb 4, 2005 | 06:16 PM
Vette Boy's Avatar
Vette Boy
Originally Posted by LEXUS_KID
...I have nothing but problems with those batterys every color to from red, yellow and the blue they all seem not to last as long as they should.
I bought a red one for my Impala years ago. Lasted three winter...$130 for a three year battery? Now I buy the $60 Autozone and replace it every three years as part of preventive maintance.
chippy1202
IS F (2008-2014)
28
Oct 22, 2015 08:19 PM
Two-Times
Jul 9, 2015 08:45 PM
is250jz
Sep 8, 2012 10:08 PM
Stormwind
Aug 13, 2008 08:06 AM
bezeeduzit
Oct 13, 2004 10:08 AM
