Torque Coverter as a first mod?
Originally posted by redgs4
I'm sure you will let us know which is heavier, but my guess is that the 3.76 unit is much heavier -- look at all the extra gearing crammed into that pumpkin.
Stock diff and Supra Torsen diff weigh pretty close to the same. I think it's the casing that's super heavy. I recently shipped a stock diff and it was 93lbs. I think the Supra one is about the same.
While having my 3.76 LSD installed today (see my new thread) I weighed it and the stock unit
TT Supra 3.76 LSD: 93.5 lbs
Stock GS400 diff: 86.5 lbs
Easy to see why when you see them both side by side up close- the Supra LSD housing is larger! There is an area underneath like a sump for more gear lube and also more heat sink fins cast into the housing. There could also be a slight weight increase due to the Torsen gear mechanism inside.
More info on the diff. thread....
nanotech
Aug 1, 2001 12:56 PM
