lsd info
Old May 19, 2004 | 06:41 AM
anajri's Avatar
anajri
Default lsd info
hey guys
I just FINALLY found a Supra lsd. I have done my research but there are two things that I'm still not sure. How can you tell if the lsd is from a supra 6-speed or an Auto? Can you tell? and I know the gearing for the 6 speed lsd is wrong but What would happen if it is from a 6speed and I install it.?
I'm picking it up later today? Any thoughts?
Old May 19, 2004 | 12:15 PM
FutureGS400's Avatar
FutureGS400
I'm not sure about the gearing difference between a 6 speed and auto, but do make sure it is actually a limited slip diff (LSD)-not all Supra diffs were.
You probably already know this if you've done your research, but just in case....
Hope it works out OK!
Old May 23, 2004 | 07:56 PM
Hermosa's Avatar
Hermosa
Well if it's 6 spd you might need a different half shaft than stock most likely.
Old May 23, 2004 | 11:37 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
The rear end from a 6speed is 3.27:1, which is the same as a stock GS400.
The automatic Supra Turbo rear end is 3.76:1 plus it is a direct bolt on vs the 6 speed which requires different half shafts.
If your sticking to NA power, then the 3.76 gears are perfect and higly recommended. I will be swaping the LSD from my 3.76 box to the stock 3.27 box due to pending SC.
Lee
Old May 24, 2004 | 05:25 AM
Hermosa's Avatar
Hermosa
Actually the Supra Turbo 6spd is 3.133.
Here is a link to an earlier post I made regarding the Supra Differentials.
https://www.clublexus.com/forums/sho...lsd#post483557
OneRedSc
Aug 20, 2014 12:13 AM
XxPainxX
Sep 2, 2011 10:48 PM
Ken'sGS300
GS - 1st Gen (1993-1997)
Nov 22, 2010 10:58 AM
wgs400pr
Performance
Mar 23, 2006 02:19 PM
lex400sc
Oct 28, 2004 03:13 PM
