2008 IS250 sprung clutch disk help
Old Mar 8, 2025 | 10:36 AM
lxxxmannnchase's Avatar
lxxxmannnchase
3rd Gear
Default 2008 IS250 sprung clutch disk help
I have a question about a 2008 is250 clutch.
i am using the p gear steel single mass flywheel from Taiwan
i also have an oem new aisin pressure plate.
my question is what sprung clutch disk will work with the oem throwout bearing part.( not sure what its called but the part the bearing clips to, that seats around the clutch plate and the clutch fork interacts with )
on the oem clutch plate (aisin dt-170 unsprung) it fits with the oem release throw out bearing part i just need to find a sprung disk with the same diameter as the oem disk. if you can point me in the right direction i would really appreciate that.
apologies for my lack of knowledge of proper part names.
ive added photos of the flange/spline outer diameter that im trying to find on a sprung disk.
Defender46
May 19, 2022 06:10 PM
250boi
Performance
Aug 20, 2021 09:33 AM
