Headers for V8 cars, Please read
Old Mar 23, 2005 | 05:04 PM
  #346
Hollywood's Avatar
Hollywood
Personally I dont need to wait for the assesment. I know they will be better. I'm ready to buy.
Old Mar 23, 2005 | 08:15 PM
  #347
Dx3's Avatar
Dx3
Guys,
I am very interested but a little confused. If someone could answer these questions I would greatly appreciate it. They will be going on a 95 Sc400.
1. Approximate labor time including reworking for the SC400?
2. The write-up says this about the 95 SC400 - No EGR provisions will be made so the installer will need to consider this if they choose to retain EGR.
What exactly does this mean? Oklahoma does not have inspections so I don't have to worry about that - but will this not mean I will have a CEL on all the time?
Thx,
Jonny
Old Mar 23, 2005 | 10:04 PM
  #348
JBrady's Avatar
JBrady
Originally Posted by Dx3
Guys,
Thx,
Jonny
#1 - hard to say, depends on what you do about EGR, cats, the rest of the exhaust, who does the work, on jackstands or in a shop with a lift, air tools and professional mechanics. My guess is a minimum 4 hours and it goes from there.
#2 - all 1UZFE engines (Lexus V8) from 1990-1997 had EGR. These manifolds will not have the small 2 bolt flange that the EGR connects to. It is fairly straighforward to weld on a flange and route the EGR. Some simply block it off. There are many posts regarding this if you do a search.
Here is a picture of the SC400 manifold with the EGR flange showing between the back port and the catalyst flange.
Old Mar 23, 2005 | 10:18 PM
  #349
Dx3's Avatar
Dx3
Thank you for your response - much appreciated. One last question. Does the motor need to be pulled or can this be done without doing that?
Thx again,
Jonny
Old Mar 24, 2005 | 06:14 AM
  #350
JBrady's Avatar
JBrady
Thx again,
Jonny
Jonny,
Since yours is a 95 SC400, rated at 250hp/260tq, I am assuming (yes I understand the risk in doing so) that is shares exhaust manifolds with the 1992-1994 SC400s. In this case you should not have to pull the engine. Actually, I anticipate that the engine will not have to be pulled for any year or model, just unbolted and lifted slightly for clearance. The problem is with the newer twin tube manifolds for 1995-2000 LS400s and 1998-2000 SC400s (with 1996-1997 SC400s being an unknown at the moment) there is no room to remove the heat shields and these shields prevent access to the head studs/nuts. Since multiple people have successfully replaced the earlier cars manifolds with headers WITHOUT pulling the engine we know that is not a problem with early cars.
Ironically, the 2001+ 430 engines went back to a single tube design (which holds back power but heats the cats faster) and for these cars install may be easier than the 1995-2000 cars (excluding the 85 SC400). On the 430 cars a new downpipe/Y-pipe/catalyst assembly will need to be fabricated.
Here is another picture of the prototype to compare to the 1992-1995 SC400 passenger side exhaust manifold (with EGR) shown above. Notice the outlet location is farther away from the engine and the dramatic improvement in design.
Old Mar 24, 2005 | 07:04 AM
  #351
Fisher503's Avatar
Fisher503
J Brady you said "On the 430 cars a new downpipe/Y-pipe/catalyst assembly will need to be fabricated. " Is your fabricator going to have these ready to go on to the car? What do you think something like that will cost to have done if your guy will not do it?
Old Mar 24, 2005 | 08:17 AM
  #352
Hollywood's Avatar
Hollywood
It will be reasonable. That kind of stuff does not cost much at a custom exhaust shop.
On the gs430 I had it on the lift, some of the header bolts can be access from the bottom some from the top, seems no reason to pull the engine at all. There seems sufficient space to move around from underneath the car this is where most of the work will take place on a GS430. A mechanic with a lift and air tools with fancy ratchet joints will have a definate advantange on all the header swaps.
Old Mar 24, 2005 | 06:38 PM
  #353
JBrady's Avatar
JBrady
No, the fabricator is not going to build this part... at least not at this time. Best bet is to find a good muffler shop or speed shop that builds exhaust systems. Now, if you want to remove yours and ship it out for prototype work I may be able to assist in building a part.
The reason this applies for 430 cars is that Lexus changed manifolds and that changes mounting location for the catalysts. They also went to a 3 catalyst Y pipe, 2 at the manifold outlets and one as the 2 side join into one. It would be VERY easy for a shop to simply build you an off road Y pipe without cats. You could add cats to this system for about $125 each. I would personally not cut up the stock system for parts but that is also an option.
Old Mar 24, 2005 | 06:43 PM
  #354
JBrady's Avatar
JBrady
This is very good news and should mean installation on 430 cars is a fairly easy task.
Old Mar 25, 2005 | 07:53 PM
  #355
mdwtexas's Avatar
mdwtexas
Registered User
I am interested in the group buy for the headers for a 1998 gs 400 . Jbrady , I sent you an pm .
Thanks!
Old Mar 26, 2005 | 01:59 PM
  #356
BA_GS400's Avatar
BA_GS400
John, this is fantastic news! AND, I have to say that the pic of the one header looks pretty darn sweet, all things considered!! The stock exhaust manifold is indeed crappy!
I vote that the user Anthracite doesn't get a set since he "can't be bothered" with the length of the project. Perhaps he'll make his own set! lol! Yeah, ok, that's mean, but, I can do without the "world revolves around me" attitude he displayed.
John, the amount of time and effort you have put into keeping this project alive, working with the fabricator's, updating the thread, etc is under-appreciated. We'll all be in-debted when you pull this off and we're the benefactors.
On the headers: I too am a litle worried about the sound, that is my only caveat to wondering if I'll be happy with them. The price is probably not going to be an issue.
Do you have any idea how the header coating would compare to Jet-Hot in durability? Opinions?
Thanks John! Looking forward to the continued updates!
Allan
Old Mar 27, 2005 | 10:52 PM
  #357
Aikido's Avatar
Aikido
Post 2004 tundra truck
Hey I have a question I have a 2004 V8 double cab 4 wheel drive truck. Tundra sweet truck
1. Trd has no headers for 2004 and 2005 , lookin for a pair for my truck, and if there is will it bolt up to my factory exhaust, or do i need to make mods to put them together.
currently all i have for mods on this truck is a K@n filter and a Borla cat-back exhaust system for alittle extra power and nice sound. anything else out there for external bolt for more horsepower needs.
Any info on this would be appreciated!!!!!
Old Mar 27, 2005 | 11:45 PM
  #358
SC400TT's Avatar
SC400TT
Default Tundra Headers
I have a set of T304 Stainless Headers specifically for the Tundra. Never used, Still in the box. I will sell them to you for $215.00. They are made for the Tundra, perfect fit...
I bought them for my SC400 TT project, and am making a set instead...Better fit for my car if I make them.
Let me know if you're interested...If not, they are going on eBay.
Ryan Allen
Old Mar 28, 2005 | 10:01 AM
  #359
Hollywood's Avatar
Hollywood
Jet coating is way better, if you dont mind the baby blue color.
Old Mar 28, 2005 | 02:48 PM
  #360
BA_GS400's Avatar
BA_GS400
http://www.jet-hot.com/index.html
