Question: 2017 IS 350 Muffler Delete w/ Welded Stock Exhaust & Tip
Old Jun 29, 2023 | 08:47 AM
treygk's Avatar
treygk
8th Gear
Default Question: 2017 IS 350 Muffler Delete w/ Welded Stock Exhaust & Tip
If I were to delete the muffler from my exhaust and weld it, what type of exhaust sound should I expect to get? I’m also aware that I may be able to change the resonators or delete them. I would do that in addition to the muffler delete if the muffler delete alone sounds bad. Any thoughts?
Last edited by treygk; Jun 29, 2023 at 09:02 AM. Reason: To make my title more specific
Old Jul 6, 2023 | 09:43 PM
McGuirk's Avatar
McGuirk
10th Gear
Three options:
Commit to a full straight pipe. Which I don't recommend on these IS Platforms ever.
OR delete the secondary cats, and mess with the resonator, and leave on the stock mufflers.
OR delete the secondary cats, leave the stock resonator, then get some kind of Axle-Back with more "flow" with quad tips/nicer dual tips.
I don't recommend to delete or change resonators. I have yet to see a delete or custom that does not result in major drone throughout the cabin. OR that does not result/produce cabin rattle/vibrations as compared to stock.
When changing mufflers. Borla is one of the most expensive, but produces the best sound both inside/out IMO. Although they only come with dual tips.
You can find off-brand quad-tip mufflers for 1/3rd of the price of the Borla/others on Ebay. Which is the route I went, as they are the only mufflers I could find with quad-tips.
Old Jul 7, 2023 | 11:28 AM
EdgarLex's Avatar
EdgarLex
Originally Posted by McGuirk
Three options:
Option 4: He can do a muffler delete no problem. Keep everything stock but delete the mufflers.
Old Jul 7, 2023 | 12:56 PM
ScytheDC's Avatar
ScytheDC
If you want sound then you need to get rid of the mufflers. It will sound wonderful.
Old Jul 10, 2023 | 04:38 AM
rileybrok's Avatar
rileybrok
1st Gear
Mufflers & Sounds
Old Jul 10, 2023 | 06:34 AM
Nexus713's Avatar
Nexus713
If you don’t mind drone while cruising on highway then muffler delete it is 😅
Old Jul 11, 2023 | 07:17 AM
McGuirk's Avatar
McGuirk
10th Gear
Muffler delete is the fastest way to a ticket/mandatory vehicle inspection by the popos in Canada. Which is why I didn't list it as an option.
I imagine its probably the same across most states. Especially in Cali
Old Jul 11, 2023 | 10:17 AM
ScytheDC's Avatar
ScytheDC
Probably in CA due to noise restrictions. But many states in the US do not care. Mufflers aren’t doing anything for emissions anyway so you’ll pass most state inspections without them.
richy350
Jun 14, 2020 09:02 AM
Vuongto12
Apr 9, 2019 07:10 AM
mikexay
Performance
Apr 12, 2016 12:50 AM
F_Throttle
IS F (2008-2014)
Nov 12, 2014 07:25 PM
Gerb
Jul 18, 2014 06:59 AM
