Sc400 not turning on at all
Old Jun 18, 2022 | 05:36 PM
keysean's Avatar
keysean
1st Gear
Default Sc400 not turning on at all
I’m new to cars I just got this sc 400 three months ago and two months ago it’s been sitting because it won’t crank or do anything no lights turning on or anything so I been thinking and trying to find a way I just found this forum today so I’m giving it a try I looked it up and seen that the battery terminal is all beat up but before it was working I looked online to find more terminals but the no one had the same one I had for sell so I just been working and letting the car sit while I been doing my research
Old Jun 18, 2022 | 07:47 PM
Arsenii's Avatar
Arsenii
Hello,
Is it the wire or the battery terminal that is beat up?
Beat up terminal can result in a very small contact area between said terminal and the battery itself, which may not allow enough current to power the car. Any car parts store can check the condition of the battery for free if you bring it in, so you may as well try, if it is the battery terminals that are beat up, you will need a new battery. If it is the wire terminals that are bad, you can get new ones from the dealership, Part Numbers are 90982-05030 and 90982-06022.
If that won't help, check all the fuses, I do mean ALL of them, here is a fuse diagram for your car.
Hope this helps and best of luck!
COOLIS
Aug 27, 2015 02:34 PM
MattStarr
Oct 16, 2012 05:57 PM
iridebmx
Sep 20, 2012 11:46 PM
94Blexus
Apr 8, 2011 09:07 PM
