Center cat delete = back fire?
Old May 25, 2022 | 02:01 PM
WhosAlex's Avatar
WhosAlex
Default Center cat delete = back fire?
Hello I’m getting my exhaust done and it’s going to be straight piped from the two front cats back. I was wondering if removing all the mufflers, center cat, and resonators would cause it to back fire when the exhaust gets hot. Also will removing the center cat cause any problems? Such as throwing off lights or losing power. Im going to be using 2.5” piping. Thanks
Old May 26, 2022 | 05:13 AM
CLass of 1's Avatar
CLass of 1
There’s a lot of information on this topic. It’s been proven that straight pipes will lose power. You should retain the factory piping from the cats to the first Y (before the center cat) and from that Y make a straight pipe (2.5”), or add a resonator. That straight center section will be split to a Y at the back like factory, using an aftermarket Y, or 2-1 merge collector. From this second Y, reduce piping diameter to 2.25” to the rear mufflers.
So, to recap:
Factory components you’re keeping:
Front cats
Front Y
Aftermarket components you’re upgrading:
Center piping
Rear Y
Rear piping
Mufflers
This has been tested to be the best way to extract the most power on a lightly modified SC400.
Nick
Old May 26, 2022 | 09:38 AM
RudysSC's Avatar
RudysSC
^ Nick is correct! And you shouldn't have any problems removing the rear center cat. I passed emissions here in CO without mine and just the front primaries.
Old May 26, 2022 | 12:25 PM
CLass of 1's Avatar
CLass of 1
I learned from your posts, Rudy! Thanks for sharing your knowledge with the community.
Nick
Old May 27, 2022 | 08:58 AM
RudysSC's Avatar
RudysSC
Of course, Nick! Always glad to give a little back to a site that has given me so much!
WhosAlex
May 6, 2022 01:48 PM
GasBuggy
Jun 28, 2016 11:29 AM
ATP123
Mar 2, 2014 10:39 PM
assass1n
Apr 12, 2009 11:31 AM
RobSoVIP
Aug 23, 2003 06:12 PM
