1995 SC400 Rough Idle/Misfires
2nd gear
So I've been trying to diagnose my SC400 for the last couple days and am looking for some guidance.
The car starts up and runs perfectly for about a minute. After that, it runs very rough at lower rpm (<2500). When you put the car in Drive with the brake holding the car in place, the whole thing shakes and seems to miss firing a cylinder. The rumble happens at ~40 mph (~2000 rpm) unless I turn off overdrive.
This is my second SC. When the first was doing something similar, it was rough at all speeds and rpm. That was a simple ignition coil replacement for the driver's side.
I thought this was a similar situation so I replaced the passenger side coil and all the spark plugs (driver's side coil is confirmed good).
The car has no CEL and gave no OBD 1 codes (just endless CEL blinking)
I checked the resistance of the driver's side fuel injectors and the frontmost passenger's side and they all are within spec. The others are under the Throttle body so I will test them if I can eliminate all the components that don't require the engine apart.
I used a jumper to bypass the Fuel Pump ECU and that did nothing
I tested and got sparks on all 8 cylinders
The O2 sensor 2 was working correctly according to the voltage feedback at the diagnostics port but O2 1 may need to be replaced.
The other part that I suspect from reading other posts is the ISCV
Any thoughts?
Any thoughts?
2nd gear
Update:
I pulled the ISCV and measured resistance at the terminals as per the service manual. B1 to S1/S3 gave 46 ohms and B2 to S2/S4 gave 45 ohms while spec is 10-30 ohms. Looking into replacement options (over $1k new at Autozone)
