power steering pump crush washers
Hi guys. I'm going to be changing the power steering pump this weekend on my '99 Sc300 and I wanted to know if anyone knows the size of the crush washers for the hose? I bought some on Amazon and they are 20mm x 16mm x 2mm. Not sure if these will fit but if not any help would be appreciated. Thanks
Equalizir (02-22-19)
I have my complete steering overhaul in my build thread with oem part numbers:
https://www.clublexus.com/forums/bui...l#post10044290
On the SC the rack side and pump side are the same height, but on the supra the rack side and pump side are different. You most likely ordered the washers for the supra rack side (which is narrower). The Supra pump side and SC washers are the same.
You should be fine with those. The high pressure line is 16mm ID and the low pressure line (rack side) is 17mm (can only be bought from lexus).
ND92Lexus
Performance & Maintenance
04-09-13 10:39 AM
