Transmission problem: car won't get into gear
Old 12-11-16, 09:09 AM
lem321
lem321's Avatar
Default Transmission problem: car won't get into gear
I tried driving my car the other day after not driving it for over a month. It started slowly as I suspect the battery was undercharged. The car would engage in Reverse but not in Drive. It felt like it was stuck in Park. Stepping on the gas revved the engine (while in Drive) but no movement. I finally was able to get it to move forward in the lowest gear. The other gears finally engaged and the car seemed to drive okay after that.
Is is this an mechanical problem (transmission) or an electrical one? BTW, my car is a stock 2000 SC400 automatic with 140k miles. Thanks in advance for any advice or help you can offer.
Old 12-11-16, 09:20 AM
ThomasGS4
ThomasGS4's Avatar
Did you check the transmission fluid level?
Old 12-11-16, 09:28 AM
lem321
lem321's Avatar
Default Transmission woes
didn't check the fluid level but I will.
Thanks
Old 12-11-16, 12:55 PM
gerrb
Super Moderator
gerrb's Avatar
Next time post at the right sub-forum
Moving to Performance and Maintenance
Old 12-11-16, 02:01 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I had an instance in my SC where it would involuntarily drop out of gear. Fluid level was low. Topped it off and all was well
joeccl
07-29-15 08:16 AM
mikob
35
04-01-15 12:34 PM
ArtyJay242
10-07-14 05:14 AM
chicov8
03-16-11 04:44 PM
Quick Reply: Transmission problem: car won't get into gear
