Anybody know what size socket to use on front wheel bearing nut
I own one of those and am quite familiar with how to use it
The reason I asked was to attempt to avoid having to pull the wheel, pull the cap and measure it, then put it back together and order what I need for the job later. It was simply a question to someone who has already performed this task and knows what tools I need so as to avoid this extra task. It just so happens that a few months ago while I was changing control arms, I pulled one cap and was going to remove the nut and look at the bearing. My 34mm was too small and I said then I needed to measure it but was busy with the task at hand and didn't get that done. So, that's how I know it's larger than 34. True, should have measured it but I didn't.
That might be a little over your head, so just skip over these type posts next time.
I have a 34 that I bought for the diff yoke nut
and it was too small when I tried it last fall on the wheel bearing nut (front, just to be more specific). Like I said in previous post, should have measured then but didn't. Guess I'll just go to the trouble of getting to the cap and pulling it off to measure the nut.
