AEM V2 wont sync! AEM gurus needed
So here is my blight, i cannot get aem v2 to stat sync so i cant get my lexus to start.
i monitor the t2per channels and i do get cam and crank signal.
i still am using stock distributor.
any insight?
any insight?
mess with the initial crank pulse, if you installed larger injectors then lower that number for the desired temp range. once you get stat sync, basically the ecu only does initial crank pulse (cold start fuel) and uses the crank angle on the engine start page, so play with those 2. often you can leave the crank angle alone. If that doesn't work then just throw that ecu away or use it as a doorstop.
Super Moderator
I have seen it many times . One day you got stat sync , next day you don't . I had enough of them . One day I had to argue with an AEM customer service that there was something wrong with the new box I just bought from a dealer cause the damn car was running with another box.
One has to wonder why Ali did away with his AEM ecu . hahahahhah
Reef13
Performance & Maintenance
17
11-23-15 07:45 AM
winner155
24
02-15-12 05:13 PM
