1992 sc300 ecu
Old 01-25-14, 06:35 AM
riobanks
riobanks's Avatar
Talking 1992 sc300 ecu
So I replaced my ecu out of my 1992 sc300 with a 1993 sc300 but it would not start. Would could be the problem? I put my old one back in and it would crank. Also their is a little metal loop in the back of the ecu box that i did not hook when plugging in ecu. does that matter??
Old 01-25-14, 07:52 PM
grumpi300
grumpi300's Avatar
Yes it does. The ecu has to have the exact numbers on them. I believe they all start with 89661- and from there the numbers change. Each pin in the ecu is different for different year sc's.
Old 01-26-14, 01:26 PM
Tam4511
Tam4511's Avatar
this is false. All Ecu's are compatible for the same models between 92-94, only 95's are compatible with 95's, 96-98's are compatible with each other, and 99+'s are.
WadeLovell
12
03-14-14 11:51 AM
Ali SC3
SC400 / 300 Classifieds
01-10-14 04:19 AM
Trax
01-31-13 04:50 PM
jth3rd
01-14-09 08:20 PM
Quick Reply: 1992 sc300 ecu
