From the look of it your LSD is fine but you must inspect all those little spider gears for damage. That is a Torsen gear-type LSD, not a clutch-type TRD LSD. The ring gear, however, is blown. You WILL need to replace that, along with a matching pinion.
Some people here are skilled enough to rebuild a differential, measure the tolerances with a micrometer and apply the correct shim thickness but I highly recommend sending it out to a differential shop for service.
What kind of driving were you doing when you noticed the sound and felt something different? What horsepower are you running?
Regardless, this is a good time to look into choosing a ratio as per your specific needs. 3.769:1 is somewhat rare but you can also switch to a 3.916:1 from an SC400 rear diff as those are fairly cheap and plentiful.
Thank you very much for the reply. When you say 3.916 gear ratio from a sc400 how will that help me out? I know shorter gearing will give me better acceleration. But what do I need from the sc400 differential? (What parts) do u know where I can go about getting parts to rebuild mine?
you need the parts from it that your broke, mainly that large ring gear with the stripped teeth and the pinion, and probably good idea to stop double clutching. the larger ring gear (missing teeth in your picture) is what sets the ratio, so you have the chance to change ratios by getting the right ring gear, and there are lots of ratios to choose from, search for the differential thread.
