SC300/400 and MKIV Supra A/C condensers physically the same?
Old 08-30-13, 04:21 PM
KahnBB6
KahnBB6's Avatar
Received 1,222 Likes on 857 Posts
Default SC300/400 and MKIV Supra A/C condensers physically the same?
I'm sorting out my A/C system and may need to replace my A/C condenser. Though it might seem obvious because the part numbers are clearly different, can anyone confirm from experience if the Supra MKIV A/C condenser is physically the same as the SC300/400 A/C condenser?
Just wondering.
For reference, here are the part numbers for both:
88460-24070 sc300/400 A/C condenser
88460-14290 Supra MKIV A/C condenser
Old 08-30-13, 06:43 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Well you answered my question. I was going to tell you that 300/400 were the same. Sorry I couldn't be much more help.
Old 08-30-13, 07:59 PM
KahnBB6
KahnBB6's Avatar
That's okay! It's at least one less thing to figure out
I'm still in shock at the cost of the SC condenser even if you can find it discounted from list. Same for the SC heater control valve. Unbelievable.
Old 08-30-13, 09:01 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Would you consider a new/used one? There might be one here locally at the LKQ junk yard...
Old 08-31-13, 12:42 PM
KahnBB6
KahnBB6's Avatar
Thanks, but I'd only consider a used one of either if I knew for sure they were tested or in observable in working order. If I'm replacing I don't want a surprise down the road with A/C. I've got an LKQ branch in town as well. Might try that. So far I'm into a remanufactured Aisin compressor which he confirmed wasn't in good shape and I knew this for a while (records indicate it's 110k in age). I'm going to deal with the other two parts next week when my mechanic checks for dye on my A/C lines.
Old 09-01-13, 04:29 AM
F4A22
F4A22's Avatar
Get aftermarket.
Old 09-01-13, 06:47 AM
KahnBB6
KahnBB6's Avatar
^^ Please could you tell me where I can find an aftermarket condenser for these cars? I wasn't aware we had the option for a bolt-in replacement.
Edit: Is the factory part made by Denso?
Old 09-01-13, 08:45 AM
KahnBB6
KahnBB6's Avatar
Found a source, thanks. The Denso direct fit part is sold outside the Toyota system. Will see if I'm right.
Denso
PART#: FS33589 MFR#: 33589
dseag2
09-28-14 02:07 PM
gorjusguy
SC- 1st Gen (1992-2000)
33
02-09-10 08:27 PM
Star08
04-30-08 12:00 PM
xknowonex
31
05-10-05 12:03 AM
ac300
Suspension and Brakes
10-16-02 06:12 AM
Quick Reply: SC300/400 and MKIV Supra A/C condensers physically the same?
