People in the US - Engine Swap Question
Old 12-13-02, 10:04 AM
Idrockasupra
Idrockasupra's Avatar
Default People in the US
I have a question, I have heard of people that will do the 2JZGTE swap for the Lexus with the transmission for 2000 if the parts are given to them ? I would REALLY appreciate it if someone could give me a number or site to someone who did, thank you.
Old 12-14-02, 12:55 AM
VQT
VQT's Avatar
You are talking about $2000 on labor to change the engine and the transmission...You provide the new engine and transmission...
Anyone can do it just ask you local garage. Its just a matter of taking off parts, engine mounts, disconnect the drive shaft from the transmission and get a cherry picker (engine lift)...and you're home free
Old 12-14-02, 01:30 AM
RaynArt
RaynArt's Avatar
since we're on the subject, how does everyone deal with emmisions etc?
Old 12-14-02, 02:26 AM
Idrockasupra
The 2JZGTE is emissions compliant in the USA if that what you mean, a 50 dollar tip to your local garage that tests emissions does it too
Old 12-14-02, 02:33 AM
Idrockasupra
Oh where can I get the engine mounts that are needed ? I know that their is some people that will lengthen the drive shaft.Ok this is my list of what I need.
1. Engine
2. Trans
3. Harness
4. LSD( I will be using the TRD LSD made for the supra)
5. Lengthened drive shaft
6. Custom exhaust of some sort
7. FMIC, but can't I just use the stock SMIC ?
Thanks for the help
Old 12-14-02, 04:16 AM
RaynArt
RaynArt's Avatar
i understand the 2jzgte is emmisions compliant, pehaps i phrased my question wrong. anyway, what i meant was that will there be any extra paper work or anything since the motor didnt originally come from that car? or can they even understand that its a supra motor?
Old 12-14-02, 10:36 AM
Hermosa
Hermosa's Avatar
Yes you can. We actually have the opening for this. If you remove the air box you will see the opening. I have one for sale as well if you want one.
Old 12-19-02, 11:44 PM
philauldridge
philauldridge's Avatar
Default engine mounts and exhaust
you shouldn't need anything in the way of engine mounts. the -GTE will slide right into the existing lexus mounts with no mods.
I bought a standard MK IV downpipe (Rod Millen, or others), with no cat (strictly for off-road, of course!), and it mated perfectly with the Greddy dual exhaust made specifically for the Lexus.
If you use the Supra cat(s), you may find the fit a bit tight in the trans tunnel area, but a few whacks with a big hammer can solve that problem!
for the Getrag conversion, there's a good detail description on the suprastore.com site (I can't recommend them as a source to deal with, however)
manish1607
08-30-15 04:59 PM
Sett26
05-09-15 06:52 PM
trcarnut
03-24-13 05:17 PM
BRIANxJDM
GS - 1st Gen (1993-1997)
01-11-10 02:11 PM
Quick Reply: People in the US - Engine Swap Question
