common oil leaks?
Old 10-18-12, 07:54 PM
maynanator
maynanator's Avatar
Default common oil leaks?
my car seems to have formed an oil leak recently. i was wondering if these cars have any common oil leaks. thanks.
Old 10-18-12, 08:18 PM
OG Dada
OG Dada's Avatar
Valve cover gaskets, cam oil seal, crank oil seal, oil pressure switch, power steering pump, power steering hose, rack and pinion seal, oil pan gasket, tranny oil pan gasket.... You didn't really specify anything, so there you go.
Old 10-18-12, 08:31 PM
maynanator
maynanator's Avatar
ok thanks, it's most likely engine oil, also it's coming from the bottom of the engine closer to the passenger side right behind the wheel.
Old 10-20-12, 08:17 PM
2jznosht
2jznosht's Avatar
Add distributor o ring to the list if your car has a distributor
Jpdelaunay
RX - 1st Gen (1999-2003)
01-08-17 11:00 AM
Sactolex
SC- 1st Gen (1992-2000)
13
12-18-15 06:00 PM
SpencerT
08-12-12 11:08 PM
GS300 I6
GS - 1st Gen (1993-1997)
03-07-10 11:40 PM
TouringGS
Performance
02-08-04 12:46 PM
Quick Reply: common oil leaks?
